f22b vtec swap into 97 accord lx problems...help please
Old Apr 8, 2008 | 12:40 PM
KHMERXB0I213's Avatar
Default f22b vtec swap into 97 accord lx problems...help please
i just swap a single cam vtec into my lx accord and it wont start...it cranks but doesnt start...theres fuel tho....any tips?
Old Apr 8, 2008 | 12:41 PM
Default Re: f22b vtec swap into 97 accord lx problems...help please (KHMERXB0I213)
Old Apr 8, 2008 | 06:52 PM
m0nee's Avatar
Was there any known problems with the EX motor before you swapped it in your car?
Check your battery, distributor coil, igniter, and wires. Make sure all your ground wires are connected (tranny, motor, and at water neck where the thermostat is located), and make sure you have no bad/burnt fuse.
Old Apr 8, 2008 | 07:21 PM
dleccord's Avatar
did you forget to install spark plugs?
Old Apr 8, 2008 | 11:57 PM
check all fuse and replace blown ones....gonna try to buy new dizzy...and the ex motor i bought from local shop...GSPEED...
Old Apr 9, 2008 | 04:39 AM
bseriescrxsi's Avatar
some f22bs used crank sensors while others didnt.....if your original motor used one and this one didnt that may be the problem
Old Apr 9, 2008 | 07:06 AM
accord99power's Avatar
did you check for spark?
Old Apr 9, 2008 | 06:20 PM
Default Re: f22b vtec swap into 97 accord lx problems...help please (bseriescrxsi)
it was originally a lx and non vtec.. and we swap the vtec motor wit the lx manifold and wire harness..and no theres no spark
Old Apr 9, 2008 | 07:37 PM
did you put a new ecu in for the vtec harness
Old Apr 9, 2008 | 11:10 PM
no ima try to get the car running first then get a vtec ecu and wire up vtec...cuz im using the lx non vtec harness
Old Apr 10, 2008 | 05:34 PM
JuNkDoGAccOrD's Avatar
i did the same swap on my 94 LX and I had to rewire the harness to accept the new dizzy cuz the vtec dizzy is internal coil and the non vtec has external coil which means extra plugs on the harness
Old Apr 11, 2008 | 08:11 AM
Default Re: f22b vtec swap into 97 accord lx problems...help please (JuNkDoGAccOrD)
x2 ......to see if this is your problem take the wire that goes to your external coil and put a fuse in the end with the 2 wires side by side(the fuse will sit right in, thats how you will know what 2 i am talking about) then try to start the car....if it starts that was your problem
Old Apr 11, 2008 | 12:37 PM
i dont really get u ...wat dizzy do i use? lx or vtec?
Old Apr 11, 2008 | 01:22 PM
is if you swaped in a VTEC engine u need a VTEC dizzy and if ur using a non vtec harness u need to get it re-wired
Old Apr 12, 2008 | 09:31 AM
ANY WAY I CAN JUST RUN NON VTEC FOR NOW?
Old Apr 12, 2008 | 10:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KHMERXB0I213 &raquo;</TD></TR><TR><TD CLASS="quote">ANY WAY I CAN JUST RUN NON VTEC FOR NOW?</TD></TR></TABLE>
Old Apr 12, 2008 | 12:45 PM
yes you can go without wiring the vtec.....but your car will top out in RPM at about 4000-5000k because of it.....i wouldnt leave it like that for too long though
Old Apr 14, 2008 | 10:08 AM
ok i talked to my homie and he said the vtec engine doesnt come wit a crank sensor so ill just get a vtec ecu and try to start it....anyone oppose?
Old Apr 14, 2008 | 02:53 PM
GITER DONE LoL
Old Apr 15, 2008 | 12:54 PM
i noe i want to get it done..but i need a ecu just to test it out...anyone in LA have a ex ecu the wanna let me use just to start it?
Old Apr 15, 2008 | 01:34 PM
As long as u have the Vtec Dizzy wired up and dont have the vtec wire up or the vtec ecu u can still start up the car with a non Vtec ecu....... sounds kinda weird when u read it hope u get it
Old Apr 15, 2008 | 01:48 PM
hondaguy#1's Avatar
yah homie your ignition get msd on it
Old Apr 15, 2008 | 02:07 PM
THE THING IS THAT I HAVE THE LX DIZZY AND THE LX HARNESS..
Old Apr 23, 2008 | 10:59 AM
dam....no crank sensor..lx dizzy...will a ex ecu get it to staart?
Old Apr 23, 2008 | 11:55 PM
truckhigh's Avatar
ive done this b4 and ive done a couple accord.
what motor do you have the obd1 or obd 2
if you have a obd 1 motor wire the external coil and crank angle sensor (between main pulley adn intake manifold 4wire plug) to the vtec dizzy. Or you can swap oil pump and use lx dizzy and coil. too much time.
obd2
just wire up the internal coil from you external coil.
you need to use your vtec dizzy and wire it up so that you dont do it later when you get your ecu.
