vtec stoped working. no check engine light.
i pulled the seloniod off and cleaned it and found aluminum shavings......but everything seems fine. no knocking or noise from motor???????......vtec tries to engage and will when its below operating temp.(vtec controler). but when it gets warm it like sputters in and out of vtec???? so the real questin is where did that metal come from??? i changed the oil/filter imeadiatly and found nothing anywhere else????? does that mean its comig from the head somewhere???
Modified by ludedude1984 at 7:40 AM 4/8/2008
Well I was going to go into more detail, however since I obviously must not have a reason to ask those questions, do a little reading and search next time.
https://honda-tech.com/zerothread?id=830163
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedude1984 »</TD></TR><TR><TD CLASS="quote">ive had the vafc ever since i put the motor in so im not sure.</TD></TR></TABLE>
it wont take much. i went threw the same prob my oil pan was alittle dented and no vtec. but change the pan. i went threw wiring ecu everything it ended up being the thing i never thought it would be. the oil pan.
Dont expect anything good to come of the metal shavings. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedude1984 »</TD></TR><TR><TD CLASS="quote">thanks people. ill give it a try. uhh... so.... the metal shavings in my vtec solinoid
FrontwheelENT
14
Aug 20, 2012 05:30 AM
Just Checking In
Jun 3, 2003 10:47 PM
