D16 Si motor + GSR Throttle Body?
Old Apr 8, 2008 | 06:06 AM
JasonKarl's Avatar
Default D16 Si motor + GSR Throttle Body?
D16 Si motor + GSR Throttle Body, will this work?
I picked one up, it was on a b-series crx. Im a bit confused though, im new to tuning cars.
Anyone done this before?
Old Apr 8, 2008 | 11:32 AM
es.roadster's Avatar
Default Re: D16 Si motor + GSR Throttle Body? (JasonKarl)
Old Apr 8, 2008 | 09:52 PM
davens's Avatar
What are you trying to accomplish?
What other kind of mods are on this engine?
Just swapping in a B-series throttle body will net minimal gains and will probably even hurt fuel economy.
If you need a "bigger" throttle body, stick with stock and send it off to http://www.maxbore.com/
Old Apr 9, 2008 | 04:37 AM
JasonKarl's Avatar
Default Re: D16 Si motor + GSR Throttle Body? (davens)
cool, thanks alot!
Old Apr 9, 2008 | 06:12 AM
Red_ED8's Avatar
B series TB's will only work if you have a Y8 intake manifold.
Old Apr 9, 2008 | 06:28 AM
Default Re: D16 Si motor + GSR Throttle Body? (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">B series TB's will only work if you have a Y8 intake manifold.</TD></TR></TABLE>
they will fit any sohc vtec engines
97grnrs's Avatar
they also work on any 92-95 intake mani too. ive done it.
Old Apr 9, 2008 | 10:49 AM
JasonKarl's Avatar
Default Re: D16 Si motor + GSR Throttle Body? (97grnrs)
well then,
would you say its worth it? I mean that port job on a d series TB is 100 bucks.
You fellas with the experience, care to explain which hoses link where on the new TB?
Old Apr 9, 2008 | 10:50 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">B series TB's will only work if you have a Y8 intake manifold.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es.roadster &raquo;</TD></TR><TR><TD CLASS="quote">
they will fit any sohc vtec engines </TD></TR></TABLE> They will fit ANY 92-00 Intake Manifolds (probably even the silly Y7 manifold as well).
Old Apr 9, 2008 | 12:25 PM
90efhatch's Avatar
Default Re: D16 Si motor + GSR Throttle Body? (dr_latino999)
Agree with the 92-00 part have no clue on the y7. I put a b series on my d15b and it works fine. The bolt holes are way off on the 88-91 mpfi intakes.
Old Apr 9, 2008 | 02:32 PM
Red_ED8's Avatar
Default Re: D16 Si motor + GSR Throttle Body? (90efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> They will fit ANY 92-00 Intake Manifolds (probably even the silly Y7 manifold as well).</TD></TR></TABLE>
thanks for the info correction.
Old Apr 9, 2008 | 02:33 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonKarl &raquo;</TD></TR><TR><TD CLASS="quote">well then,
you gotta pay to play.
but im sure your stock motor wont benefit from neither a B series TB or a ported D series TB.
Elevorett
Apr 14, 2007 01:29 PM
donaldmejr
Mar 12, 2005 06:06 PM
Vera
Nov 22, 2003 09:17 PM
goula SOS
Jun 24, 2003 02:53 PM
dxcivic
Feb 17, 2003 03:56 PM
