BUY PARST WHERE?/internals
Okay Boys and girls So soon i will be taking my motor apart and redoing the piston rings and main and rod bearings including the thrush washers . Along with all new gaskets (Headgasket set). So other then Honda where would you guy's trust your parts from?.
Which parts store would you guys get your **** from because i was thinking ADVANCE AUTO PARTS/ http://WWW.partsamerica.com.
my friend works for a local dealership so i either go there or http://www.hondapartsdeals.com
or...
http://www.acuraoemparts.com
hope that helps
or...
hope that helps
that **** is way overpriced. Check out http://www.fjdistributors.com/ He uses good quality stuff and for a great price. Check out his turbo super kits but if you contact him he'll give you a hell of a deal without the pistons. I paid about 200 for all the seals and gaskets, bearings, head gasket, timing belt, and pistion rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks »</TD></TR><TR><TD CLASS="quote">my friend works for a local dealership so i either go there or http://www.hondapartsdeals.com
or...
hope that helps
http://www.hondapartsdeals.com would be your best bet for cheap oem parts
or...
hope that helps
</TD></TR></TABLE>http://www.hondapartsdeals.com would be your best bet for cheap oem parts
mymeatb18"
Dec 22, 2005 02:39 PM
