Gas smell !
Old Jul 10, 2002 | 06:10 PM
SpoonPL's Avatar
Default Gas smell !
It smells like gas when I do a hard right turn. There's nothing leaking in the engine bay.
It seems to be coming form inside the car, near the hole for the gas. I remember that sometimes our car smells like gas when a part near the hole is broken, but I dont remember what it is. I also checked the pipe that goes in the tank and everything seems ok (A stripped interior ownz).
Please help!
Old Jul 10, 2002 | 06:20 PM
Soled Out's Avatar
Default Re: Gas smell ! (SpoonPL)
look up underneath your car and see if your gas tank is leaking around the middle, mine does the same thing, i need to fix it
Old Jul 10, 2002 | 06:31 PM
SpoonPL's Avatar
Default Re: Gas smell ! (Honduh hatchboX)
MMmmm thanks, ill check it out tomorow
Old Jul 10, 2002 | 06:52 PM
ZCPOWER's Avatar
Make sure your gas cap is properly closed.This will also cause you to have a gas smell inside your car.I have done it several times.
Old Jul 11, 2002 | 04:18 PM
SpoonPL's Avatar
Default Re: Gas smell ! (ZCPOWER)
Can it be because the motor is running rich and I was part throttle??
PL
Old Jul 11, 2002 | 04:20 PM
95lsvteg's Avatar
it's your gas tank i had the same problem when i had a full tank of gas......... it sucked...
Old Jul 11, 2002 | 04:31 PM
Soled Out's Avatar
Default Re: Gas smell ! (silver88zc)
did u check out your gas tank yet?? does it only do it over half tank?
Old Jul 11, 2002 | 06:41 PM
efvader's Avatar
my gas lines corroded and it leaks underneath. i need to fix it soon. lucky i have another car.
Old Jul 11, 2002 | 06:49 PM
gutted spec's Avatar
New User
Default Re: Gas smell ! (efvader)
Have you replaced your fuel pump at all? I dropped a GSR pump in mine and didn't quite get one gasket in place perfectly, and now all I smell is gas until half tank or so (hard turns, of course). I just need to get the tank down again and fix it. Might have been the vent tube. I think. I dunno.
Old Jul 11, 2002 | 06:52 PM
SpoonPL's Avatar
No, it stopped doing it, but the tank was full when it happened.
I'll check it out tomorow, I had no time this week.
pepsi813
Honda CR-V & Element
May 19, 2019 12:41 PM
Bowl_of_Rice
Feb 27, 2011 06:27 AM
mikeszutu
Oct 13, 2008 07:27 PM
ekdriven
Jun 8, 2004 08:39 AM
ggangtong81
Oct 12, 2003 06:23 PM
