gsr swap wont start, please help.
Old Apr 7, 2008 | 07:09 PM
DCRbullet's Avatar
Default gsr swap wont start, please help.
hey guys,i was doing a wire tuck and after hours of work and finishing everything i tried to start the car and it clicked and the battery died completely.... so i put some jumper cables and hooked it up to another car and it just clicks a lot from around the starter
please help me out, thanks for your time.
Old Apr 7, 2008 | 07:12 PM
crazyguy's Avatar
Default Re: gsr swap wont start, please help. (DCRbullet)
does fuel pump prime? check all the fuses and ground wires and any loose wires/connectors?
Old Apr 7, 2008 | 07:13 PM
Mugen112's Avatar
Make sure all of the grounds and connections are secure in place. Otherwise, your starter might be bad (may have fried the solenoid somehow) . A clicking noise usually just indicates a low battery, but if you tired to jump it, it may be bad. Take it out and have it tested at autozone. With a gsr, it only takes like 10-15 minutes to take it out with hand tools. Make sure you take the negative terminal off the battery post if you do.
Old Apr 7, 2008 | 07:20 PM
DCRbullet's Avatar
Default Re: (Mugen112)
thanks i think it prob. is the starter im not sure how i would of messed it up but i think it might have something to do with disconnecting the battery or fuel injectors, i will do that tomorow.
thanks!
Old Apr 7, 2008 | 07:30 PM
Mugen112's Avatar
On second thought, test your battery before you take your starter out. If your battery is completely dead, it wont start with a jump either. So try that first. ( its a little easier to take that out and have it tested instead of the starter lol).
Old Apr 7, 2008 | 07:34 PM
DCRbullet's Avatar
but the thing is it wasnt an issue until after i did all this......wait actually leaving the radio on for like ten minuted would drain the s**** out of te battery. u might b on to something, haha thanks i appreciate it.
Old Apr 7, 2008 | 07:38 PM
bubblebrain's Avatar
Default Re: (DCRbullet)
weird, my brother's car just did that today too. but now it doesn't even click. i wonder whats wrong...?
jgett002
Aug 3, 2016 02:00 PM
92'si
Jan 24, 2012 12:03 PM
egtony
May 18, 2009 09:58 AM
Ph0eNix
Dec 15, 2005 11:58 AM
See Are X
Mar 6, 2003 10:08 PM
