Question for the Honda techians
Old Apr 7, 2008 | 04:19 PM
redcvchtch's Avatar
New User
Default Question for the Honda techians
allright i've got a 99 civic hatch with a b18b1 turbo and i belive it is only after the car warms up but at partial throttle it boggs so bad that the engine almost dies. If i keep pushing the gas it will just miss really bad. I push the clutch in and rev it a few times and it goes away for a little bit. I have allready put new plugs in and gapped them at 42 i think but could it be doing this b/c my dsm injectors could be failing. I just bought the car and the egr valve was hooked up to some pipe that did not lead to the canistor the car does not have one. Needless to say im just trying to find out what is making it bog/miss any help would be appreciated thanks
Old Apr 7, 2008 | 05:45 PM
redcvchtch's Avatar
New User
anyone have any ideas?
Old Apr 7, 2008 | 07:48 PM
ekb16's Avatar
any codes?
Old Apr 7, 2008 | 07:49 PM
Acidcrakker's Avatar
Default Re: (redcvchtch)
Unplug your EGR and see if that helps with the bogging. Doubtful
Why do you have DSM injectors on a honda?
Check your timing. Have you had your injectors tested? Any codes?
Old Apr 8, 2008 | 04:58 AM
redcvchtch's Avatar
New User
no codes, not sure how to check timing, and dsm injectors b/c they are cheap low imp injectors
h23vtec_dc2
Mar 10, 2010 06:44 PM
aryiman98civic
Feb 23, 2007 07:03 AM
dominate9
May 16, 2005 05:38 AM
ThaCivicAssassin
Apr 5, 2005 06:02 PM
djnikko
Aug 5, 2003 09:14 AM
