94 civic cranks but doesn't start. Need help.
Old Apr 7, 2008 | 04:13 PM
EGfosho's Avatar
OG Tech
Default 94 civic cranks but doesn't start. Need help.
I did search and replace a lot of parts on my own before posting this. My friend's 1994 Honda Civic EX is having trouble starting. The car will start up fine when it is cold. When the car is warm and the radiator fan is not on, the car just cranks and you start to smell a lot of fuel. But if the car is warm and the radiator fan is on, the car will start up fine. The fuel pump is priming, no CEI, checked timing, checked spark. The only thing I did not check was the compression. I replace the ignition coil, the rotor, dist. cap, spark plug wires, spark plugs, main relay, checked fuses, cleaned out the injectors, clean out the fuel rail. Does anyone know WTF is going on with this civic?
Old Apr 7, 2008 | 04:32 PM
crazyguy's Avatar
Default Re: 94 civic cranks but doesn't start. Need help. (EGfosho)
check your starter. hot wire it and see and hear if it clicks and turns
Old Apr 7, 2008 | 07:12 PM
EGfosho's Avatar
OG Tech
Default Re: 94 civic cranks but doesn't start. Need help. (crazyguy)
It cranks and turns, but doesn't start. It is like those old cars that take a while to crank over and start, but it just keeps on cranking.
Old Apr 8, 2008 | 02:08 PM
EGfosho's Avatar
OG Tech
Old Apr 8, 2008 | 02:10 PM
obuhmyuh's Avatar
you didnt mention anything about the battery... how old is it? check the basics, battery, alternator, grounds, make sure everything is plugged in...
Old Apr 8, 2008 | 02:20 PM
Former User's Avatar
Check the fast Idle Valve:
Old Apr 8, 2008 | 02:24 PM
obuhmyuh's Avatar
Default Re: 94 civic cranks but doesn't start. Need help. (RonJ@HT)
good info, where did you get it?
Old Apr 8, 2008 | 02:27 PM
Default Re: 94 civic cranks but doesn't start. Need help. (obuhmyuh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh &raquo;</TD></TR><TR><TD CLASS="quote">good info, where did you get it?</TD></TR></TABLE>
http://hondatech.info/downloads/Auto/Manuals/Civic/
Old Apr 8, 2008 | 02:31 PM
obuhmyuh's Avatar
thanks
Old Apr 8, 2008 | 10:33 PM
EGfosho's Avatar
OG Tech
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh &raquo;</TD></TR><TR><TD CLASS="quote">you didnt mention anything about the battery... how old is it? check the basics, battery, alternator, grounds, make sure everything is plugged in...</TD></TR></TABLE>
I know it is not the battery or the alternator. You can crank for along time if you want, plenty of juice. I just have to wait for an hour until the engine cools off in order to start the car again. I check all three major ground cables in the engine bay and they seem fine also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT &raquo;</TD></TR><TR><TD CLASS="quote">Check the fast Idle Valve:</TD></TR></TABLE>
that could be it. Thanks for the info.
Modified by EGfosho at 11:54 PM 4/8/2008
Old Apr 9, 2008 | 08:50 PM
EGfosho's Avatar
OG Tech
k. today i replaced the fast idle valve and checked it. It works just fine.
I also replaced the thermostat since there was none!!
So this is the deal. It only stalls on me when the engine is hot and left alone for a few min (5-10min). When i crank, i can smell gas and if i do not wait too long about (1-3min) before i crank again i can get it started but it sputters and miss-fires almost as if its dumping fuel into the chamber and flooding it so it takes a few sec before it reaches normal idle again. sorry for the tough explanation but i tried to relate as detailed as possible, any other suggestion?
feava510
Feb 15, 2009 10:59 AM
PinkMaggit
16
Nov 28, 2008 05:25 PM
99Civic-EX
19
May 29, 2007 07:35 PM
SilverGT
Dec 2, 2006 03:12 PM
civic efb16
Aug 8, 2005 09:00 PM
