Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Wind noise
Old Apr 7, 2008 | 12:25 PM
fuhok's Avatar
Default Wind noise
Hey guys,
I got an '07 Si Sedan and have been noticing a whole lot of wind noise coming from the front driver and passenger windows. Do any of you guys have this issue?
I did show them the weather seal around the front right door and they're ordering a new one. I wonder if both need to be replaced. Driver and passenger side.
While I'm at it.
I had posted or responded on the windshield creaking about a month ago. Took the car to the dealer for the 10K service and went for a ride with the workshop foreman. He did hear the noise and they pulled the plastic cowl by the wipers and put some sticky foam stuff. Didn't do crap. The creaks are still there.
I'll give them another try to figure out how to fix this annoying creaking noise after that I'll have the replace the windshield which I actually mentioned and they didn't mind.
'07 Civic Si - Fiji Blue (K&N drop in filter)
Had a '05 Accord EX-V6
(lowered with H&R springs, H&R wheel spacers, Neuspeed stress bar, Comptech rear sway bar). Missed it.
Old Apr 7, 2008 | 03:24 PM
si92hb's Avatar
Default Re: Wind noise (fuhok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuhok &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
While I'm at it.
Just an FYI, but one of the 2008 LX models I test drove had this issue. The two others I test drove as well as the one I purchased did not have this issue.
Old Apr 9, 2008 | 05:45 AM
fuhok's Avatar
Default Re: Wind noise (si92hb)
Thanks si92hb.
Anyone else?
I'm talking about the new Civic body style. It's so annoying having the wind noise from both sides of the front doors. I will definitely ask the dealer to replace the weatherstrips around both the front doors. I actually did a test where I taped over the outside of the passenger door where it comes down and then turns straight down. Thought maybe the wind was coming thru there. Test drove it but nothing still had the noise. I just don't get where it's coming from.
There's got to be others out there that have this issue. Anyone? Anyone find a fix?
Hey si92hb, do you have the windshield creaking issue that people have posted on here? Thanks again for your feedback.
Old Apr 10, 2008 | 09:23 PM
fg2si!kid's Avatar
New User
i hear it too does not botherme to much though
Old Apr 10, 2008 | 10:47 PM
clemsonhatch's Avatar
Default Re: Wind noise (fg2si!kid)
You're punching a hole though the air it's going to make noise.
Old Apr 11, 2008 | 12:46 PM
knaira112387's Avatar
the creaking is from the weather stripping that holds the windshield in place.. just have them reinstall them and it should be fine.
Old Apr 13, 2008 | 07:47 AM
fuhok's Avatar
Default Re: (knaira112387)
do you mean pull the windshield and get it reinstalled?
i noticed some other people on the forum had similar issues reported.
thanks for the info.
the sound definitely sounds like it's coming from the inside area where the windshield meets the dash. and i have noticed that they have installed some type of foam across the entire dash.
Old Apr 20, 2008 | 06:06 PM
fuhok's Avatar
Actually the creaking proved to be the cowl just in front of the windshield. Between the hood and windshield. They replaced the cowl and the noise is gone. No more creaking.
As far as the wind noise. It was noticeable on the front passenger door. They replaced the weatherstrip around the door and the noise was minimized quite a bit. It's not the way it was before. The car is a lot quiter now. It's not like the '05 Accord I had but it's much better. That's to be expected I guess. Totally different cars.
Well, that's what I got so far. So for anyone that might have creaking up front by the dash area ask the dealer to look at the plastic cowl. The windshield washer sprayers are part of the cowl.
Old Apr 24, 2008 | 09:48 PM
tendou's Avatar
hi i also have sedan si 07 and lately i been hearing noises coming from the passenger side window. Both of my weather seals in the front doors were never assembled correctly because you see ends flapping outside. I went to the dealership to and showed it to them. They did nothing. I also showed them the panel below the seatbell on the passenger side popping loose. Once again they did nothing. I went to different dealership nothing and I told them specifically that they might have to replace it because popping it back in won't help, they think i'm like an idiot or something. I'm pretty sure there is something wrong the windows because you hear the rattling noise if the window is down and I asked people just to make sure if it is a problem and they said yes, it shouldn't make a rattling noise. So frustrated
Old Apr 24, 2008 | 09:57 PM
Westrock2000's Avatar
Default Re: Wind noise (tendou)
Funny cause I think mine is the quietest car I have ever been in I was actually commenting on the lack of wind noise at 70-80 MPH.
Ep3180
Feb 26, 2016 12:34 PM
aznromeo4u
Feb 20, 2015 11:12 AM
Trackready
Apr 27, 2013 08:09 PM
fuhok
Nov 21, 2008 08:16 PM
BongoBennie
Jan 14, 2005 10:16 AM
