Cam gear placement.
I have been having a hesitant response when at idle and I have checked most of all the possible culprits. I have been comaring my h22 cam gear position to my h23 vtec cam gear position and the H22 seems like it is off by a tooth on the timing belt. I don't know where the exact position of the cam gears should be. Anyone have pics or a diagram?
well with the engine at TDC, there are lil marks on the cam gears that should be pointing directly at each other on the inside, and they are on the front and back of the gear, they should line up right above the upper timing belt cover on the outside. If you can't figure it out from that I can post a pic if needed, or get ahold of a Helm's manual and theres great illustrations of it in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ketchup »</TD></TR><TR><TD CLASS="quote">Since my valve cover is off..
that picture isnt showing much since cylinder 1 is not at TDC
</TD></TR></TABLE>that picture isnt showing much since cylinder 1 is not at TDC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">
that picture isnt showing much since cylinder 1 is not at TDC</TD></TR></TABLE>
just showing him the <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snobordboi »</TD></TR><TR><TD CLASS="quote">lil marks on the cam gears that should be pointing directly at each other on the inside</TD></TR></TABLE>
since the other pic was a bit blurry..
DMCCOY
12
Jan 9, 2009 08:39 PM
