OKay, I might be having idle problems 95 Accord EX or it could be something else
I have a 95 Accord Ex 5 speed 4 cylinder
The Idle stays pretty even at about 800 - 1000 RPMs
But it has these "Dips in Power" That's what I call them.
I thought it was Vacuum issues because I just put in a SRI.
So I took the SRI out and reinstalled it. Double checking everything again.
I capped the 2 Vacuum hoses also.
It is still doing the same thing.
So it was suggested that I check the IACV and the FITV, but I have no clue where they are.
I did a search and found a similar thread about the 92 accord, but the pics of the engine are different.
So if I could get some assistance I would be grateful.
Also, Something I noticed today.
I had the car on after reinstalling the SRI and I slowly stepped on the accelerator and i felt the engine "Jerk" 2 or 3 times, the RPMs were about 800 - 1200
So I went under the hood and accelerated the car and I saw the engine jerk.
But once the car got to about 1500 RPMs and up, the jerking stopped.
Anyone have any tips or suggestions for me.
Thanks
Thanks
Come on
42 views and No one has any nuggets of Wisdom?
Surely someone has an idea
Just point me in the right direction
I had quite a bit of maintenance done lately on my 96 Honda EX 6cyl, timing belt, alternator, starter, main relay, ignition switch. I did the last three, my mechanic did the first two. Today, the idle was really low, like 500 or lower, die a couple times. I went to the Acrua thread and found the pics. The Honda's IACV is similar. I clean mine and now it seems ok, idling at about 800rpm steady like before.
p.s. I only wiped clean the two holes, especially the one with screen . It was completely covered with scrudge.
https://honda-tech.com/zero...age=1
