starter issue...
Old Apr 7, 2008 | 10:36 AM
DAtegLs's Avatar
Default starter issue...
ok i had a bad starter im my newest project. (93 civic ex) so i went and got a new one from work (Advance) and threw it in. the starter would engage and spin but the car wouldnt crank...all you hear is the starter spin and it sounds like its just not catching the torque converter. i went back to work and got the starter AND battery tested...both good...
no blown fuses
everything looks tight
no corrosion
still have no idea...any help would be awesome?
thanks.
Old Apr 7, 2008 | 11:11 AM
blk92_d16's Avatar
Guessing it's an auto? Okay, do you have fuel?spark? air?
Old Apr 7, 2008 | 11:16 AM
DAtegLs's Avatar
Default Re: (blk92_d16)
huh?
Old Apr 7, 2008 | 11:17 AM
DAtegLs's Avatar
oh excuse my last post...
yeah it ran fine when the old starter was workin.
Old Apr 8, 2008 | 06:08 PM
DAtegLs's Avatar
Default Re: starter issue... (DAtegLs)
its still got me stumped! does any one with a d16z6 have a part number from there starter that i could get to possibly compare starters? i did a part# check at work and it brought up p.# 17217...anyone have a remanufactured part from a parts store with a number? oh and yeah its an auto...
Old Apr 8, 2008 | 07:31 PM
grandtheftlunchbox's Avatar
This has happened to a bunch of b16a's i've built. try loosening the bolts that hold the starter on and moving the starter towards the flexplate (not the torque converter like you said). there should be a little play in it, but move it as close to the flexplate as you can. this should solve your problem.
Carlos23
Honda CR-V & Element
Aug 14, 2017 08:35 PM
crazyhouse2011
May 23, 2013 08:23 PM
pasenast
Apr 14, 2007 04:20 PM
HXvtec
Nov 6, 2004 02:15 PM
