F/S: 96 GSR(P72) head
Sellin for a friend
contact Jamal at 336-408-3499 or message me on here
UP 4 sale is my 96 GSR(p72) cylinder head. It is in working condition. It has had the valves brushed and lapped for a good seal. It comes with
vtec solenoid
96 GSR cams
stock cam gears
all cam caps
cam cap bolts
both coolant temp sensors
coolant neck
has new Victor Reinz valve stem seals(Car quest)
em valve cover
lus some necessary nuts/bolts
intake manifold with
OBD-1 injectors
fuel rail
fuel pressure reg
throttle body
map sensor
tps sensor
intake air temp sensor
asking $550 firm,no trades, buyer pays shipping!
vtec solenoid
96 GSR cams
stock cam gears
all cam caps
cam cap bolts
coolant neck
em valve cover
OBD-1 injectors
fuel rail
fuel pressure reg
throttle body
map sensor
tps sensor
null.
Jun 23, 2007 01:22 PM
