pin changes with B16 swap?
to B16 swapped car owners: did you repin your ecu at all or just add the wires for the vtec components? i have already added my wires and inserted the pin into the #1 clip for the vtec solenoid, but my car will not start up?? not even when i undid the wiring and put it back to stock? what is the story here? thanks.
It wont start as in no spark or no fuel or neither. Does it crank? You need to be more specific. I got 10.00 on it being a bad ground. Make sure your engine harness ground thats on the thermostat housing is connected. Make sur you have a ground wire going from the battery to the frame of the car AND one that goes to the clutch cable bracket. 8-10 cars I have been called to come fix have been poor grounds.
smash fascism
Apr 8, 2005 05:39 PM
89s1
Aug 5, 2004 02:34 PM
