IAB WIRING (JDM GSR ENGINE/ECU/ usdm wiring harness...
Old Apr 7, 2008 | 05:55 AM
B18CmeFLYby's Avatar
Default IAB WIRING (JDM GSR ENGINE/ECU/ usdm wiring harness...
Car- 94 acura integra/ usdm
motor- jdm gsr
wiring harness, usdm gsr
ecu- JDM P72
SOLENOID WORKS. VACUUM LINES ARE CORRECT.
MY IABS DO NOT WORK. yellow and black wire go to....?
PINK (used to be red im guessin but faded out) and blueish wire go to....?
Ive gotten MANY different answers by searching...does anyone have a deffinate answer?
any help would be great..i dont want to fry anything by wiring or grounding the wrong wires.
Modified by B18CmeFLYby at 12:22 PM 4/7/2008
Old Oct 25, 2008 | 04:15 PM
Without Limit CRX's Avatar
Default Re: IAB WIRING (JDM GSR ENGINE/ECU/ usdm wiring harness... (B18CmeFLYby)
Yellow black goes to a 12v+ (the 12v+ from the 02 sensor will work) ( blue needs to go to the ecu. (its the signal) not sure what pin # on the ecu, sorry. and if this didnt fix it, go yellowblack to ecu and blue to the power! one way will work...
Old Oct 25, 2008 | 04:17 PM
Default Re: IAB WIRING (Without Limit CRX)
also make sure the IAB is cleaned up inside!
Old Nov 6, 2008 | 09:08 AM
forth page number 5, look.
link:
http://www.boomslang.us/obd0_1.pdf
maybe this will help? hope so... not 100%
Old Apr 9, 2009 | 06:13 PM
yaaj313's Avatar
New User
hey, i need help. where is the iab wire located on the motor? and what wire goes where to make it to run right? i got a 94 ex with a 95 gsr motor, using a p28 ecu. my wire harness is the 94 ex too. somehow my car runs but it does not kick in vtec, it seem it running like a ls motor... and i think it's that wire, not letting air in...? need help, thanks...
Old Apr 9, 2009 | 09:05 PM
g2daturbo's Avatar
Post Re: IAB WIRING (JDM GSR ENGINE/ECU/ usdm wiring harness...
p28 ecu does not have the output for the iab control.. also check the vtec wiring.. pressure switch and solenoid,, most people swap out the stock intake for a aftermarket without the iab's but if ur gonna use them i would rec. a p72 ecu
Old Apr 10, 2009 | 05:12 AM
sitinduk's Avatar
On a jdm p72 (square) ecu pin A17 is +12v not ground like usdm obd1 ecus. The other wire that connects to the iab solenoid has to be grounded.
IAB Info. Look down at the obd2/jdm section
Dukie432
30
Mar 31, 2009 04:37 PM
B18CmeFLYby
Apr 7, 2008 12:38 PM
EVIL Hx Coupe
Mar 23, 2005 11:05 AM
43MA
Feb 25, 2003 06:49 PM
