[Help] What are the best COILOVERS for stock crx struts
What are the best COILOVERS for stock crx suspension....to make it easier...what are the best coilovers i can use to replace my OEM springs and lower my car
Simply put, none. It's an OEM strut designed for an OEM spring. Anything else will result in some sort of compromise. Having said that, any coilover sleeve will work with your stock strut but the key is to KNOW that if you go too low it'll blow your STOCK struts sooner rather than later.
xJu1c3x
Apr 7, 2008 09:08 AM
