Most Efficent RPM Range?
Old Apr 6, 2008 | 08:57 PM
Importn2oRacer's Avatar
Default Most Efficent RPM Range?
Whats the most efficient and economical rpm range for driving in a 6th gen accord? I noticed at 2000 rpm its exactly at 55mph. But in newer cars 2000 rpm is at 70mph. I assume anywhere between 2000-2800 rpm?
Old Apr 6, 2008 | 09:07 PM
TheMuffinMan's Avatar
He knows where you live!
9000rpm
Anything under 3k realistically.
Old Apr 7, 2008 | 10:26 AM
SOHCMAN's Avatar
Default Re: (TheMuffinMan)
To be at 2K at 70 would require a good overdrive top gear, and is more likely to be found in larger displacement motors (v6 v8)
There will be I4 exceptions I'm sure. Maybe one with a 6 speed tranny??
Assuming you have a 4 cyl, the most economical rpm I have ever driven my accord was at 2000 rpm/55mph yielding around 36 mpg. It was ideal conditions, a good road, and possibly with a tail wind
Usually I see around 30 mpg on the highway, and you have to remember that its not only about engine speed, but also aerodynamics. The faster you go, the more drag is working against your cars fuel efficiency...
sohc
Old Apr 7, 2008 | 10:55 AM
kd97accord's Avatar
i find mine works best at 120 km/h with 91 octane. That's just me. I think im running about 3k when im at it.
Old Apr 7, 2008 | 03:30 PM
professorman's Avatar
Default Re: (kd97accord)
Dont bother with 91 octane. Do your research about octane and you will see it doesnt result in any increase MPG. Generally, keeping it under 3k RPM is efficient. The Accord have pretty tall gear ratios compared to other Hondas. I seen Preludes rev somwhere around 4k RPM going about 70MPH, (I think).
Old Apr 7, 2008 | 03:34 PM
Yep, use what's recommended, the higher the octane, the more it compresses before it explodes so you really don't want to run it in your 87 recommended car.
Old Apr 7, 2008 | 06:52 PM
YeuEmMaiMai's Avatar
my CL type S is 1500 rpm for 55mph 2K gets you 75mph. 4.2K and you have hit the fuel cutoff at approximately 150mph
my old 98 accord it was 1700 for 55 and 2K for 70
my 94 was 2800 for 70 and 2400 for 55 that car was great of gas 80 mph at 34mpg
Old Apr 7, 2008 | 09:44 PM
SOHCMAN's Avatar
Default Re: (YeuEmMaiMai)
To be clear about high octane fuels, as muffinman said, a high octane fuel will be able to burn with out detonating from either too high compression or excess heat. Neither of which are present on a stock engine that reccomends 87 octane.
Using 91 will not hurt your engine, only your wallet. If you are racing or other wise abusing your engine, excess heat could build up, and in that case a high octane fuel WILL prevent premature ignition (knocking/detonation/etc) and prevent resulting engine damage.
So if you're taking it to the track, go for it, otherwise, highway driving is very easy on engines and wont require excessive octane.
sohc
Jesse Johnson
Acura TSX
Mar 31, 2016 10:59 AM
Mahalaleel
39
May 8, 2012 11:10 AM
Ruskimafia
Jan 1, 2006 05:23 PM
s2k
Jul 7, 2002 02:01 PM
