need to know what connects
Old Apr 6, 2008 | 08:35 PM
paniaguae640's Avatar
Default need to know what connects
i found these cables behind my center console not plugged in my 94 honda prelude si, was wondering if anyone knew where these are connected and also what they are for? Also my ABS light is on, just for records.
Old Apr 6, 2008 | 08:56 PM
H22Luda720's Avatar
Default Re: need to know what connects (paniaguae640)
The Two-Pin Blue connector is to check CEL codes
I have the other ones hanging loose too, never looked behind there so i dont know if i have the female connectors as well
My guess is a wheel speed sensor for your ABS light
Old Apr 6, 2008 | 09:00 PM
prelude_93vtec's Avatar
Default Re: need to know what connects (H22Luda720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Luda720 &raquo;</TD></TR><TR><TD CLASS="quote">The Two-Pin Blue connector is to check CEL codes
Old Apr 6, 2008 | 09:25 PM
Hawkze_2.3's Avatar
The blue ones are service connectors and the yellow is for the SRS (safety restraint system, or airbags).
FYI all ABS plugs will be orange, all SRS will be yellow, etc..
Old Apr 6, 2008 | 09:39 PM
no1knows908's Avatar
Default Re: need to know what connects (prelude_93vtec)
The "female connectors" are actually just dummy clips mounted to the console for those plug to sit it. Both are used for diagnostic reasons. When not using those to check trouble codes just plug them into the holder clips to keep them from moving around or getting **** in them. I'm not sure if you can self check ABS codes but I'd do a search on it.
Old Apr 7, 2008 | 04:25 PM
vlang29's Avatar
Default Re: need to know what connects (no1knows908)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no1knows908 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure if you can self check ABS codes but I'd do a search on it.</TD></TR></TABLE>
you can, it's done the exact same way as checking engine codes
civic j
Jan 5, 2008 06:12 AM
typeR564
Feb 26, 2007 10:35 PM
oilguzzler
Oct 9, 2005 12:26 PM
diyer
Jan 4, 2005 07:21 AM
quazar
Jul 9, 2004 11:44 PM
