What Type of OIL should i use
Old Apr 6, 2008 | 06:34 PM
phoshyzzle's Avatar
Default What Type of OIL should i use
i have a 1996 gsr.. 126k miles. i was told 10w30 because of mileage and i was also told 5w30 because its better for vtec motors. any suggestions?
Old Apr 6, 2008 | 07:00 PM
TOO MUCH TORQUE's Avatar
5w-30 is what acura recommends, so stick to it.
Old Apr 6, 2008 | 08:28 PM
Red4drLSintegra's Avatar
i use 10-w-30 with my integra... mobile one full synth. high mileage formula.
Old Apr 6, 2008 | 08:37 PM
DiMpL3s.'s Avatar
Default Re: (Red4drLSintegra)
i use 3qrts of 10-30 castol and 1qrt of lucas oil stabilizer... just for ***** and giggles....
Old Apr 6, 2008 | 08:44 PM
da_90_teg07's Avatar
Default Re: What Type of OIL should i use (phoshyzzle)
i used the torco 10w 30 and it made my car smoke so i wouldnt do that agen
Old Apr 7, 2008 | 04:45 PM
phoshyzzle's Avatar
thanks for the replys. any more suggestions?
Old Apr 7, 2008 | 05:14 PM
wegotmorrison's Avatar
Default Re: (phoshyzzle)
I use 5w 30 Royal Purple.. 9 bucks a quart and worth every penny.
Old Apr 7, 2008 | 05:57 PM
mrdeadman's Avatar
They let me pick
Default Re: (wegotmorrison)
Mobil one 5w-30 fully synthetic
Old Apr 7, 2008 | 07:57 PM
Blahblah718293's Avatar
Default Re: (mrdeadman)
10w-30 will give better protection, especially in warmer months.
5w-30 will flow a little more freely, but your not gonna feel any difference between the 2.
i use 10w30, just cause i like my motor to get lubed. i used castrol synth blend in my ls with 130k, it works just fine, and doesnt burn as much as the conventional i used.
Old Apr 7, 2008 | 11:09 PM
98GSRDC2's Avatar
Default Re: (Blahblah718293)
mobil 1 5w30 full synthetic. get it at walmart 23 dollar for 5 quarts
Old Apr 8, 2008 | 12:17 AM
projectgsr777's Avatar
I agree with the Mobil 1, 5w-30 full synthetic. I live in So Cal where the weather is hot but I still believe that if Acura recommends it, stick with it. You could also go with Red Line synthetic, but that costs more and besides, Mobil 1 is good enough.
Old Apr 8, 2008 | 05:49 AM
lmike6453's Avatar
mobil1 full synthetic 5w-30 strictly w/ mobil1 OIL FILTER....oil filter is key-i feel like smacking whoever uses fram on a teggy
Old Apr 8, 2008 | 08:14 AM
JDM.'s Avatar
Default Re: (lmike6453)
Penzoil 10-W30 and Fram oil filter FTW
Old Apr 8, 2008 | 08:43 AM
DiMpL3s.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wegotmorrison &raquo;</TD></TR><TR><TD CLASS="quote">I use 5w 30 Royal Purple.. 9 bucks a quart and worth every penny.</TD></TR></TABLE>
I USED THAT IN MY K20 EP3 AND I DID NOTICE A SMOOTHER IDLE AND REVING....
Old Apr 8, 2008 | 11:19 AM
NAmodified's Avatar
Default Re: (DiMpL3s.)
10-40 works good for turbo applications with about that mileage. 5-30 is good for new low mileage motors.
Old Apr 8, 2008 | 11:29 AM
Mcdc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red4drLSintegra &raquo;</TD></TR><TR><TD CLASS="quote">i use 10-w-30 with my integra... mobile one full synth. high mileage formula.
x2
Old Apr 8, 2008 | 01:14 PM
all-mtr-teg's Avatar
Castrol Syntec German Formula 0w30
Modified by all-mtr-teg at 2:21 PM 4/8/2008
Old Apr 8, 2008 | 05:41 PM
JDMDC2BOY12's Avatar
Default Re: (all-mtr-teg)
ohhh getting a good info's
Old Apr 8, 2008 | 06:27 PM
JETSPD1477's Avatar
wow you people are so new.
5w30 and 10w30 are both a 30 weight motor oil at running temperature. The only time they are different is when they are cold. thus the "5w" or 10w"
if your car burns/uses/leaks motor oil do not use a synthetic. it will just burn/use/leak oil twice as fast.
how well a motor oil lubricates is not dictated by viscosity. viscosity is the speed at which liquid flows. a higher viscosity motor oil takes longer to pressurize and reach the cylinder head/turbo charger. im not looking to get into a debate as to which brand is better... so simply put... all motor oil viscosities from brand x lubridate equally... the difference is ONLY the viscosity and how fast/slow it moves.
so in the end it's your choice. IMO synthetic motor oils are a waste on factory internal engines unless OEM specified.
Old Apr 8, 2008 | 06:55 PM
tegra2G's Avatar
Default Re: (JETSPD1477)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JETSPD1477 &raquo;</TD></TR><TR><TD CLASS="quote">
so in the end it's your choice. IMO synthetic motor oils are a waste on factory internal engines unless OEM specified.</TD></TR></TABLE>
X2
I running my castrol 5-30
Old Apr 8, 2008 | 07:53 PM
I AM WEASEL's Avatar
amsoil
Old Apr 8, 2008 | 07:55 PM
jhammond_82's Avatar
Reject Papi
Default Re: (-DC4-)
wasn't there just an oil thread the other day? anyway... i use halvoline 10w30, and k&n oil filter.
Old Apr 8, 2008 | 09:00 PM
fergy016's Avatar
If you look in the factory manual 5w-30 or 10w-30 work for your car. High mileage I usually swap to 10w-30 as it is heavier.
Old Apr 8, 2008 | 09:53 PM
bruceda9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Castrol Syntec German Formula 0w30
Modified by all-mtr-teg at 2:21 PM 4/8/2008</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DiMpL3s. &raquo;</TD></TR><TR><TD CLASS="quote">
I USED THAT IN MY K20 EP3 AND I DID NOTICE A SMOOTHER IDLE AND REVING.... </TD></TR></TABLE>
Old Apr 8, 2008 | 11:06 PM
