Just got my 404s
ok guys im getting ready to put my motor in heres the setup
b18a1
81mm srp 10:5:1
eagle rods
acl race bearings
.074 head gasket
pnp head valve job brian crower springs and retainers and the 404s
but i wanted to know to i need timing gears i hear alot of people useing cam gears to make it idle but im tuning it so it should idle right ??? and what are you guys setting you lash too???
b18a1
81mm srp 10:5:1
eagle rods
acl race bearings
.074 head gasket
Yes, get cam gears so you can adjust the cams properly for tuning....and valve lash should be set to specifications set by the manufacturer. The cams should come with a sheet that tells you what it needs to be at. Otherwise call crower or check their website for the proper specs.
Teamdiesel
16
Jun 29, 2006 11:29 PM
