Rear sway bar ST24 mm and exhaust??
Old Apr 6, 2008 | 05:54 PM
DSMkiller's Avatar
Default Rear sway bar ST24 mm and exhaust??
Hi guys
I just start the installation of my 24mm sway bart Suspension technic on my crx.. and do you think I'll need to modified the exhaust or it will fit.... the exhaust is very near of the bracket..
thanks for the support
Old Apr 6, 2008 | 06:05 PM
grog's Avatar
Default Re: Rear sway bar ST24 mm and exhaust?? (DSMkiller)
That will probably hit when you drive and around corners. Wiggle the exhaust and check to see if it has room to move. keep in mind exhaust's move around quite a bit at times.
I had to reconfigure my exhaust when i put a rear sway bar on. Even after that the OEM exhaust hangers were allowing too much movement (exhaust was hitting something on only left turns) so I got some stiffer ones to fix it.
Old Apr 7, 2008 | 01:12 PM
90efhatch's Avatar
Default Re: Rear sway bar ST24 mm and exhaust?? (grog)
You will probably want to get the exhaust redone around the sway bar. I had mine redone after I got that bar.
NeKe1point0
Aug 10, 2008 02:25 PM
kickz
Suspension & Brakes
May 20, 2008 01:42 PM
Halo
Oct 30, 2004 11:39 PM
civicmatt
Oct 17, 2002 05:43 PM
