Bad Vibration *update* || ^^Need Advice^^
Old Jul 10, 2002 | 03:44 PM
.nate's Avatar
Default Bad Vibration *update* || ^^Need Advice^^
Alright.. maybe some of you remember me posting a thread about my car vibrating badly during right hand turns. Well... I changed the axle out, and it didnt fix the problem. All the suspension bolts are OK and the wheels arent bent or half screwed in or any of that. Someone suggested it was the open-differential. SO we ripped the tranny apart and pulled the old diff out. I went to a transmission shop and the guy looked at the diff and said that there was nothing wrong with it except some normal slight wear on the spider gears.
We havent gotten the car back together yet, but Im looking for suggestions as towhat else it could be! Im completely stumped (gee thats not hard to do). Any and all suggestions are MUCH appreciated!
-=Nate
Old Jul 10, 2002 | 03:48 PM
nevergiveup's Avatar
New User
Default Re: Bad Vibration *update* || ^^Need Advice^^ (N8)
can it be your wheel bearings?
just wondering if you checked it
Old Jul 10, 2002 | 03:55 PM
.nate's Avatar
Default Re: Bad Vibration *update* || ^^Need Advice^^ (nevergiveup)
negative. they feel fine Im so stumped.. anyone else with suggestions?
-=Nate
Old Jul 10, 2002 | 04:14 PM
.nate's Avatar
What about the halfshaft? Could it be that?
Old Jul 10, 2002 | 04:17 PM
FifthGearOnline's Avatar
is the problem in the steering?!?!?!?!
Old Jul 10, 2002 | 04:23 PM
Boozted's Avatar
How tight is the rack? May have a loose mount or something. I have heard of it happening on other cars.
Old Jul 10, 2002 | 04:59 PM
.nate's Avatar
Default Re: Bad Vibration *update* || ^^Need Advice^^ (JaySolSi)
Ill check the bolts on the power steering rack tonight. Its a power steering rack with the power steering pump and **** removed...
Any more ideas/suggestions are much appreciated
[Modified by N8, 8:00 PM 7/10/2002]
Old Jul 10, 2002 | 06:21 PM
.nate's Avatar
turbodailydan
Transmission & Drivetrain
Mar 2, 2010 12:49 PM
C_H_A_D
Nov 14, 2007 11:57 PM
buzlink
16
Oct 18, 2007 07:41 PM
92ehatch
Aug 19, 2005 11:20 AM
efrex
17
May 14, 2005 06:17 PM
