ys1 s80 compatibility question
this what i have,
YS1 101193
S80 3087493
i dont know what the numbers after mean but i posted them in case they are important...
i was told the S80 has a fresh rebuild but i need the 3inch bearing, here are the numbers from the race NTN #SF06A24, i hope that helps...
the main question is, can i use the internals from the S80 in the YS1 cable case and, is it a good idea... also, need to know if i can use the axle's and clutch from the YS1 still...
-Brian
YS1 101193
S80 3087493
-Brian
yes everything from the gsr can be installed into the ys1 case with no problem..... you should use the ys1 style bearings (sealed bearings) on the gsr diff when installing into the new case...
http://www.outlawatvclub.com/u....html
im in da same shoe ur in, ive found this... looks hella difficult. so ima do a cable to hydro instead.
thank you for the link Ricextacy
it doesn't look that bad now...
if the weather is good this week end i may try to get it done...
lmk how your build goes...
Brian
Brian
nicknack25
Aug 11, 2017 08:51 PM
