shifter, bushings, and linkage questions pics (searched)
Old Apr 6, 2008 | 03:44 PM
Le13lanc's Avatar
Default shifter, bushings, and linkage questions pics (searched)
b!tch pin fell out while driving (not my fault). as u can see i bent the shifter side ends back in place some. think it's straight enough ? might try it out on a vice grip bench.
anybody have links to shifter bushings? on ebay they're all the 3 pc kits and i already have a good stabilizer bushing. i'm wanting the one that the ball joint rests in, and the bottom tube like one, don't see either of those in the kits. maybe online stealership?
anyone think a roll pin from lowes or walmart will work? thanks
Old Apr 6, 2008 | 03:56 PM
grog's Avatar
Default Re: shifter, bushings, and linkage questions pics (Le13lanc)
no that doesnt look straight. well almost, but its still tweeked a bit.
And just cough up the $3 for the factory bitch pin from honda. And dont use a bolt(unless its temporary), it will make your shifter sloppy.
You should also pick up the little clip that is supposed to prevent the bitch pin from falling out
and it looks like your missing the metal peice that goes between the rear bushing and the bolts.
http://www.hondapartscheap.com...ity=0
Modified by grog at 5:01 PM 4/6/2008
Modified by grog at 5:09 PM 4/6/2008
Old Apr 6, 2008 | 04:26 PM
Le13lanc's Avatar
Default Re: shifter, bushings, and linkage questions pics (grog)
i have the cover clip for the pin, however the mechanic left it turned open. what does that metal piece do, a spacer for the bolts?
know any thing about the bushings i mentioned?
thanks though
Old Apr 6, 2008 | 05:14 PM
grog's Avatar
honda sells it seperately, aftermarket is probably always a set.
I just had to buy a set just to get one bushing.
You could try contacting an ES dealer and asking them.
Old Apr 6, 2008 | 05:33 PM
grog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Le13lanc &raquo;</TD></TR><TR><TD CLASS="quote"> what does that metal piece do, a spacer for the bolts? </TD></TR></TABLE>
it just supports the bottom of the bushing, take a look at it in the picture in the link above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Le13lanc &raquo;</TD></TR><TR><TD CLASS="quote">i have the cover clip for the pin, however the mechanic left it turned open. </TD></TR></TABLE>
damn "deja vu"
Just two weeks ago my shift linkage fell out due to a mechanic leaving a bolt loose.
I noticed it while I was backing up, I stoped because my shifter felt loose as hell. then it dropped out.
Luckuly I was in the auto parts parking lot.
I was wondering what might have happened if I was moving at the time so thats what.
Old Apr 6, 2008 | 05:42 PM
Le13lanc's Avatar
yeh i was moving and the tow truck tore it up too, that's how the counterweight got bent. it was like having another braking system in my car!
Old Apr 15, 2008 | 10:18 AM
Le13lanc's Avatar
anyone know where this bushing goes? has me stumped. looked at a diagram from majestic honda and still not sure. thanks
Old Apr 15, 2008 | 01:52 PM
spastik's Avatar
ROFL!!!!
that part goes on the shift linkage where it bolts to the tranny
Old Apr 15, 2008 | 01:53 PM
spastik's Avatar
its number 16
http://www.hondaautomotivepart...LEVER
Old Apr 16, 2008 | 07:37 AM
Le13lanc's Avatar
ok, that one is already there and installed. i think it's aftermarket . they didn't look the same. thankyou
hillbillycivic
Mar 13, 2013 08:14 PM
Crx_Civic
Jul 25, 2007 08:29 PM
young noob
Nov 11, 2006 01:46 AM
itellyawhat
Feb 15, 2005 12:50 PM
eluder33
Nov 20, 2004 03:05 PM
