Searched through the FAQ's, still need to clarify an axle question.
Old Apr 6, 2008 | 01:13 PM
cb07's Avatar
Default Searched through the FAQ's, still need to clarify an axle question.
I have a 1988 CRX HF, but with an Si transmission. Needs a new passenger side CV.
I don't know what year the tranny is, but if we assume it's from an 88 also, I can just use a stock HF axle, right?
If I try putting in the HF axle and it doesn't fit, does that mean I need to put a tranny side Si boot/bearings/etc.., and a hub side HF setup?
That's what I'm getting, but I just want to clarify.
Old Apr 6, 2008 | 01:32 PM
97grnrs's Avatar
Default Re: Searched through the FAQ's, still need to clarify an axle question. (cb07)
i heard the hf axles will fit but the si wont. i think the hf/std hubs are diff. than si.
Old Apr 6, 2008 | 01:34 PM
cb07's Avatar
Yea see thats what I was thinking. I'll be changing to Si hubs in the future, but right now I just want a easy fix.
Because in '88, I think all three models had the same spline count in the transmission.
Old Apr 6, 2008 | 09:56 PM
crx_si-r's Avatar
Default Re: (cb07)
all you gotta do is measure your axles diameter wise. i believe u need the one from a STD model. some DX and Si axles were thicker than the HF axles. just take your old axle to the shop where u are gonna buy ur new axles and measure them.
Old Apr 7, 2008 | 07:13 AM
cb07's Avatar
So you're saying they're all the same spline, just different diameters?
Hmph.
I guess I'll find out, have to do the swap today.
Old Apr 7, 2008 | 07:15 AM
jlicrx's Avatar
Default Re: (cb07)
just get 88-91 CRX HF axle
aznboi_2
Nov 3, 2007 06:12 PM
jdmboxrocket
Feb 12, 2006 11:34 AM
Idiotboy
May 30, 2005 05:33 PM
Jul 18, 2003 06:42 PM
muskrat
Oct 30, 2002 12:20 PM
