Heads that fit on f22 block?
Old Apr 6, 2008 | 11:30 AM
corewitz's Avatar
Default Heads that fit on f22 block?
what all heads can you swap on to an f22b block. The car is a vtec, is there a way to swap any head on? its a 1995 accord ex
Old Apr 6, 2008 | 11:46 AM
casper.hughes's Avatar
Default Re: Heads that fit on f22 block? (corewitz)
if it is a vtech then you might be able to go back to the sohc not sure but i would rather have the v tech
Old Apr 6, 2008 | 04:08 PM
j_kevin_ca's Avatar
look over here.... all the info u need
<U>https://honda-tech.com/zerothread/1664547</U>
Old Apr 6, 2008 | 06:05 PM
street_accord94's Avatar
Default Re: Heads that fit on f22 block? (casper.hughes)
its spelled vtec, not the same as the electronics manufacturer vtech.
any other f series or h series heads (not including the f20c/f22c out of the s2k) can be swapped with varying levels of difficulty.
Old Apr 6, 2008 | 11:17 PM
dleccord's Avatar
yes look into the f22a1. im sure it has vtech support.
Old Apr 7, 2008 | 03:52 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by casper.hughes &raquo;</TD></TR><TR><TD CLASS="quote">if it is a vtech then you might be able to go back to the sohc not sure but i would rather have the v tech
uh, FYI... the F22B1 he has in the car now is a SOHC VTEC.
Old Apr 7, 2008 | 03:53 AM
H-T Order of Merit
Default Re: (dleccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dleccord &raquo;</TD></TR><TR><TD CLASS="quote">yes look into the f22a1. im sure it has vtech support.</TD></TR></TABLE>
nope... you can NOT add VTEC to a F22Ax head.
maal15
Jan 17, 2009 07:36 AM
lukeatkins9000
Jan 17, 2006 06:05 PM
rainydayman
Oct 17, 2005 03:53 PM
SleepingSmurf
Sep 18, 2004 09:13 AM
Radioactive
43
Apr 28, 2004 09:11 PM
