High idle after valve adjustment
I got a 93 prelude with a stock h23a1 after I did a valve adjustment the Idle is around 1700 I cant figure it out. I cont feel any vacum leaks I adjusted the valves at 0.004 for the intake and 0.006 for the exhaust plus i still A little tapping noise does anyone have any suggestions?? Any would help..Thanks
Are those the specs for the Valves, they seem a little to small. I know its not h22 but those specs are tiny. Anywho, what else have you tried to fix it?
Try to use the adjust idle screw. Or loosen the throtal cabel
yeah, the intakes are quite tight on the h23's
make sure to unplug the IACV when adjusting the idle, otherwise you are just wasting time.
check to make sure you didn't bump off a vacuum line first tho..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 »</TD></TR><TR><TD CLASS="quote">make sure to unplug the IACV when adjusting the idle, otherwise you are just wasting time.
Ive never done that, and have never had a problem, care to explain?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by music462 »</TD></TR><TR><TD CLASS="quote">I got a 93 prelude with a stock h23a1 after I did a valve adjustment the Idle is around 1700 I cant figure it out. I cont feel any vacum leaks I adjusted the valves at 0.004 for the intake and 0.006 for the exhaust plus i still A little tapping noise does anyone have any suggestions?? Any would help..Thanks</TD></TR></TABLE>
Dont touch your idle screw
Intake .006-.007 inches
Exhaust .007-.008 inches
your specs are wrong the same thing happen to me, check this thread out Read everything
https://honda-tech.com/zerothread?id=2244601
DUDE
this is an H23 not an H22
specs are as follows:
intake: .003-.004"
exhaust: .006-.007"
I really think the problem is a vacuum line that has been bumped off
intake: .003-.004"
exhaust: .006-.007"
**** i read too fast, i would tell him still check all his clearances, and al vacume hoses before he starts messing with his idle screw
