When you put a B18C5 into a CRX, do you have to....
Old Jul 10, 2002 | 02:40 PM
whobeedoobee's Avatar
Default When you put a B18C5 into a CRX, do you have to....
do you have to use a combination of first gen b16a components (trans, distributer, etc) with the type r block?
Basically, what does it take to run a B18C5 in a CRX?
I already know you need mounts....
Old Jul 10, 2002 | 03:19 PM
Veil_Side_'s Avatar
Default Re: When you put a B18C5 into a CRX, do you have to.... (whobeedoobee)
first of all my :hat: goes off to you my friend, you will be pretty fast. Besides that, I have no idea. I'd like to think you need a Type R/GS-R tranny. Don't you need like shift linkage adjusting also?
Old Jul 10, 2002 | 03:21 PM
RexB16's Avatar
Default Re: When you put a B18C5 into a CRX, do you have to.... (Veil_Side_)
basically all you will be using is the longblock (for a straightforward pre-obd swpa that is) otherwise talk to mackymcg for the complete rundown of getting an entire itr swap into a crx. including the hydro trans.
Old Jul 10, 2002 | 03:34 PM
mackymcg's Avatar
Default Re: When you put a B18C5 into a CRX, do you have to.... (RexB16)
Rex is right, you will have to use the pre-obd stuff, unless you want to get the entire wiring harness from honda, fuse boxes, ECU w/Immobi removed, etc.
If you want to run the ITR tranny, here is a link to my hydro transmission post:
https://honda-tech.com/zerothread?id=220712
Good luck, this sucker rips!
Old Jul 10, 2002 | 04:51 PM
EF_LSVtec's Avatar
Default Re: When you put a B18C5 into a CRX, do you have to.... (mackymcg)
Yup...you will use your cable tranny, non obd distributor, injector plugs and that should be it...
standy xsi
Feb 19, 2012 11:04 AM
crx-w-b18c5
Sep 25, 2010 12:50 PM
sircrxracer
Jul 16, 2007 07:15 PM
dochzc
Nov 9, 2004 12:14 PM
Aquafina
Feb 11, 2003 10:20 PM
