should i save this crx?
Old Apr 6, 2008 | 07:44 AM
janz3n's Avatar
Default should i save this crx?
so i bought this crx knowing id have to fix it up a little. its an 88 crx si with no engine i got for $900cnd. got the car delivered to my dads place and the next morning i go to take a look at the car and start working on it and the muffler hanger fell off the bottom of the floor.. great way to start this build off. so after that i decided to check the floor of the trunk. and as you can see there are plenty of holes in it.
next i took the carpet out and there are a few holes there aswell. the under body is kinda ruff aswell, along with the suspension pieces. so after gutting the car i moved to removing the rear lca's got the first one off no problem. moved to the other side and broke my friends 14mm socket. that was it for me i got pissed and just decided to stop working on it fornow. so now i dont know what to do. i want this car but i dont know if i want to spend the time and money(im an auto body apprentice so i wont be spending too much money ) saving this crx from death.
so i guessi just want some opinions on what you guys would do with this.
Old Apr 6, 2008 | 08:39 AM
civhatch90's Avatar
Well if you can do the work yourself and have the time, do it and take it as a learning experience
Old Apr 6, 2008 | 08:54 AM
es.roadster's Avatar
Default Re: (civhatch90)
umm.. that's a lot of rust. to me i don't think it's worth your time and effort, even if it was for experience. you're going to spend as much time or maybe more as if you're doing a k-swap. that's just my opinion.. goodluck to ya.
Old Apr 6, 2008 | 09:32 AM
janz3n's Avatar
Default Re: (es.roadster)
i think im gonna try and save it anyways. the trunk floor i can just cut out and put new metal easy. the underside i can just patch some holes and por15 it and undercoat it.
Old Apr 6, 2008 | 11:22 AM
Wilky's Avatar
Default Re: (janz3n)
Do it! And keep us updated.
Find a wrecked donor for the suspension pieces. Should be cheap. You will spend more money in Mig wire than anything else - lol.
Old Apr 6, 2008 | 12:01 PM
JUN.'s Avatar
Default Re: (Wilky)
nah, dont do it.... Its all rusted out.
Old Apr 6, 2008 | 12:54 PM
traxxasx's Avatar
Do it that body is to clean to waste.
Old Apr 6, 2008 | 01:14 PM
SIred91's Avatar
Rainman
Default Re: (traxxasx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">Do it that body is to clean to waste.</TD></TR></TABLE>
Are you high?
Old Apr 6, 2008 | 01:22 PM
Si-Samuri's Avatar
if you want a serious auto-body project ten go for it. good lcuk.
Old Apr 6, 2008 | 01:59 PM
zrickety's Avatar
Default Re: (Si-Samuri)
oddly, the body does look clean...except underneath. somebody drove through a lot of salt or something.
it depends on how comfortable you are with the work involved. personally, i would have to put my hands on the car to decide. i'd be torn between patching it up, fixing it right, or just re-selling it
Old Apr 6, 2008 | 02:24 PM
janz3n's Avatar
Default Re: (zrickety)
im probably just patching it up , driving it for the summer then selling it. i'llmake a project thread or just update in this one. i can make money if i sell it running anyways.
Old Apr 6, 2008 | 03:30 PM
crxcess's Avatar
you should put that car back together and sell it.
either that, or buy another one and use this one as a parts car.
Old Apr 6, 2008 | 03:33 PM
torontoefsedan's Avatar
i pity whatever retard said he'd help you out with that thing............
Old Apr 6, 2008 | 03:38 PM
janz3n's Avatar
Default Re: (torontoefsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torontoefsedan &raquo;</TD></TR><TR><TD CLASS="quote">i pity whatever retard said he'd help you out with that thing............</TD></TR></TABLE>
hahahhahahaha..you'll learn something wile doing it with me though.
Old Apr 6, 2008 | 03:59 PM
snowseeker's Avatar
Thats some funny ****!
How are the bottom of the doors, fenders, etc?
Old Apr 6, 2008 | 04:12 PM
janz3n's Avatar
Default Re: (snowseeker)
doors are great fenders are good.. quarters were fixed and just bubbling a little right now.
Old Apr 6, 2008 | 04:25 PM
AllMotoRex's Avatar
fix it!!
Old Apr 6, 2008 | 04:28 PM
snowseeker's Avatar
Do you have access to a welder and metal cutting tools? Do you want to undertake a project needing this much work? In the end you most likely will be replacing almost everything under the car.
Old Apr 6, 2008 | 04:39 PM
janz3n's Avatar
yes. my buddy has a welder. (torontoefsedan) we are more than capable of doing this project in a weekend.
Old Apr 6, 2008 | 05:06 PM
janz3n's Avatar
i also have a question, i need a x member bad , is the hatch/sedan cross member all the same? or do i have to get a crx cross member?
Old Apr 6, 2008 | 05:28 PM
jedubz's Avatar
If you're going to take this project on (which I wouldn't) heres some basic facts.
1) The rigidity of the car will never be the same. You will need a good amount of additional support in the form of suspension bars + cage.
2) Replacing all that floorboard etc will never look right and will require a lot of metal work to get pieces that fit flush, so you might be better off cutting out large sections and leaving those holes for a "full race" style.
Old Apr 6, 2008 | 05:45 PM
janz3n's Avatar
Default Re: (jedubz)
the holes arent that big that the rigidity of the car will be compromised.... and if it is theres no way you would ever be able to notice it. i dont plan on racing this car anyways. but i will be cutting most of the trunk out.
Old Apr 6, 2008 | 05:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz &raquo;</TD></TR><TR><TD CLASS="quote">If you're going to take this project on (which I wouldn't) heres some basic facts.
2) Replacing all that floorboard etc will never look right and will require a lot of metal work to get pieces that fit flush, so you might be better off cutting out large sections and leaving those holes for a "full race" style. </TD></TR></TABLE>
No offence but what the [freak] are you talking about.
Once the holes are patched it'll be good enough. It's almost a 20 year old car. No matter what its never gonna be the same.
Generally, the more welds, the more rigid it is. If you strip the seam sealer down its only spot welds, if you stitch it, it'll make it stronger.
Old Apr 6, 2008 | 08:57 PM
tree fingers's Avatar
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
Are you high?</TD></TR></TABLE>
I think maybe he only looked at the first picture..
Otherwise.. he's smoking much better **** than I've ever seen.
Old Apr 6, 2008 | 08:59 PM
bart simpson's Avatar
people save rottin trucks from the 1920s y not save this car too
