weird problem on crx, need help
Old Apr 6, 2008 | 01:28 AM
xNRxJose's Avatar
Default weird problem on crx, need help
So I'm messing with my aftermarket radio pulled out the center of dash and looked to see if I could plug in audio wires but can't, so I put it back together, I go install new light bulbs, car ran fine.
so i took a look at my driver side corner lights and had to fix the splices the previous owner did, it didnt change a thing (i didnt disconnect battery )
THE PROBLEMS:<U></U>
-when i put on my right turn signal my clock flashes until im done turning and also the trunk light in cluster stays on and dims in and out alittle when i put on turn signals
-when i put on my left turn signal my clock stays on but the trunk light in cluster dims in and out alittle
-my radio doesnt turn on
-ecu doesnt blink either
also when i turn off car and come back to it next day my clock is totally off.
Old Apr 6, 2008 | 02:25 AM
soysauce90CRXsi's Avatar
Default Re: weird problem on crx, need help (xNRxJose)
My buddy has a 96 GSR and he had all the same problems and his was the plug for his turn signal he replaced it and it has'nt done it yet. Im not sure if CRX's have that because i've never had problem with that so, its worth a shot.
Old Apr 6, 2008 | 02:32 AM
xNRxJose's Avatar
Default Re: weird problem on crx, need help (soysauce90CRXsi)
replace that, the grey that goes into bulb?
Old Apr 6, 2008 | 09:42 AM
xNRxJose's Avatar
any1?
Old Apr 6, 2008 | 03:14 PM
dbmora's Avatar
looks like u getting some type of back feed What r the wires going to turn signal for are those ur side markers or or using it to power something???
Old Apr 6, 2008 | 04:07 PM
xNRxJose's Avatar
Default Re: weird problem on crx, need help (dbmora)
Yeah its just my side lights nothing else
I went to 3 stores n they didn't have that plug
Old Apr 6, 2008 | 09:30 PM
xNRxJose's Avatar
dont know if this is associated along with the problem i have but my RPM needle moves back and forth like an applause meter. its at 3 then goes to 6 and moves back and forth between
Modified by xNRxJose at 12:41 PM 4/7/2008
Old Apr 7, 2008 | 11:42 AM
xNRxJose's Avatar
bump
Old Apr 7, 2008 | 01:23 PM
Dude I would say ur alternators goin out or u have a really bad short in ur wiring. IDK man thats all I could really think of.
Proud Virginian
Jun 7, 2016 03:00 PM
tigueremalo
Apr 16, 2008 03:18 PM
crxtreme27
May 15, 2003 05:19 PM
2kGSboi
Aug 10, 2001 02:34 PM
