need shorter alternator belt for integra
Old Apr 6, 2008 | 01:17 AM
tekstyle's Avatar
Default need shorter alternator belt for integra
i need a shorter alternator belt for my b18c. I have an OEM crank pulley that has a smaller diameter than my stock pulley. the original belt is too long and i can't tighten it anymore because the bolt is already as far back as it can be adjusted. i can hear it squeal. is there a shorter belt i can use?
Old Apr 6, 2008 | 09:51 AM
all-mtr-teg's Avatar
Default Re: need shorter alternator belt for integra (tekstyle)
Original belt length is 31 inches with 4 ribs. If you go to autozone or kragen part number is 310K4
310 = 31.0 inches
K4 or sometime R4 = 4 ribs
If you want 1 inch shorter ask for a 300K4
Old Apr 6, 2008 | 10:05 PM
tekstyle's Avatar
Default Re: need shorter alternator belt for integra (all-mtr-teg)
oh nice.. are these parts made for honda or are they just generic belts with arbitary length and ribs? thanks man.. that info helps a lot! now i dun have to go through the trouble of swapping crankpulleys
Old Apr 6, 2008 | 10:20 PM
IN VTEC's Avatar
I'd get a 30.5" and a 30.0" belt and return the one you can't use. If you're using an ITR crankshaft pulley, then it could be in between the .5" increments that U.S. belt manufacturers provide.
Old Apr 7, 2008 | 11:35 AM
tekstyle's Avatar
Default Re: need shorter alternator belt for integra (IN VTEC)
ok.. i am gonna get 3 of them. 29.5", 30", and 30.5". ordered online from autozone. the retail stores don't carry them in stock and are special order items. does anyone know if they come in a sealed packaging? i want to know if I'll be able to return them in resaleable condition. for those with experience with purchasing belts from autozone, please give your input. thank you!
Old Apr 7, 2008 | 02:27 PM
IN VTEC's Avatar
They come folded over and tucked into a cardboard sleeve. It looks like a hot pocket, only you can't eat the belt.
Old Apr 7, 2008 | 03:29 PM
tekstyle's Avatar
haha! great description. i'll order those asap. thanks guys!
Old Aug 28, 2021 | 02:02 PM
k3ntegra's Avatar
Loved
Community Favorite
I acquired a 150 amp alternator that came with a 61.5mm diameter pulley, instead of 66.0 mm on the stock 90 amp alternator.
30.5 inch serpentine belt was needed in place of the stock 31 inch belt. With 30.0 inch one would have to disconnect the alternator bracket or the crankshaft pulley to get it on the alternator.
After placing the 30.5 inch belt on, there was at least around 3/4" (19mm) on the left side of the track guide used to adjust the tension of the alternator belt.
OOOtony
Sep 25, 2007 07:56 PM
Coroner
Sep 20, 2006 05:37 PM
Threads
Oct 8, 2004 12:37 PM
siis2fast
Jun 26, 2003 09:36 AM
keithv
Aug 7, 2002 04:40 AM
