clanging noise on acceleration low rpms
Old Apr 5, 2008 | 08:41 PM
90hatchsityper's Avatar
Default clanging noise on acceleration low rpms
thee is a claning noise on my rebuilt engine, p30 type r internals, b18c block, when i accelerate on low rpms around2g you can hear it best.
any ideas? throttle cable maybe? timing belt seems to be tight with very little play
Old Apr 5, 2008 | 09:11 PM
crxfreak1117's Avatar
Default Re: clanging noise on acceleration low rpms (90hatchsityper)
LMA'S?
Old Apr 5, 2008 | 09:25 PM
GSR CRX's Avatar
Default Re: clanging noise on acceleration low rpms (crxfreak1117)
first of all are all the mounts torqued to specs. i remember i made a stupid mistake and forgot to tighten my rear tranny mount and the motor was hitting every where. just a thought.
Old Apr 6, 2008 | 10:02 AM
Default Re: clanging noise on acceleration low rpms (GSR CRX)
its a pinging under a load, i use 93 octane
Old Apr 6, 2008 | 03:17 PM
dbmora's Avatar
might be rod knock happends to the best of us did u change the oil pump ?
Old Apr 8, 2008 | 11:40 PM
sbpphoenix's Avatar
are you sure it's coming from the engine? kick your exhasut a few times and make sure it's not your resonator. mine does that and will until i got straight pipe.
Old Apr 9, 2008 | 02:42 AM
~sp33~'s Avatar
EFB055
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">LMA'S?</TD></TR></TABLE>
lamas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbmora &raquo;</TD></TR><TR><TD CLASS="quote">might be rod knock happends to the best of us did u change the oil pump ?</TD></TR></TABLE>
My guess would be rod knock.
Old Apr 9, 2008 | 01:26 PM
Default Re: (sbpphoenix)
no rod knock, this motor is brand new hasnt seen over 5 g's, and its completely balanced you cant even feel it rev.
i retard the timing the noise went away, but i believe all my problems are comming from myp30 ecu, its fit for a b16, the car is lean. needs a map made for a poor mans type r
any ideas on the base map?
j0keefe21
Jul 15, 2009 09:28 AM
Ragecloak
12
May 15, 2006 09:30 PM
dr_latino999
Aug 7, 2005 12:32 PM
