Will these Red Honda Emblems fit on an Integra ????
Old Apr 5, 2008 | 08:05 PM
H0NDAdAddy LS's Avatar
Default Will these Red Honda Emblems fit on an Integra ????
for only people who know , im not suree .
will it fit on a 94 DC4 integra ?
Old Apr 5, 2008 | 08:16 PM
Rikter's Avatar
Do some measuring of the nipples to find out if the spacing across is goign to fit. Then get out a tool that will measure the degree of angle of your trunk and your hood and check their degrees of angle to the degrees of angle of those emblems. Once you have that figured out, you'll know.
Serious, you give us NO measurements, no story from what they are off of (vehicle? ebay?) and expect a yes or no answer. Why not just test fit them?
But seriously, don't demote your Acura to a Honda. JDM is just a fad!
-Rik
Old Apr 5, 2008 | 08:19 PM
redwing24's Avatar
dude, if they don't grind those post off and use some 3m double side tape and they would work anywhere.
Old Apr 5, 2008 | 08:25 PM
its double sided tape but i think it would be morer safe just tryin to fit them pins in the holes . but if they dont fit then ill grind em off.
p.s. be niceeee ! dayumm .
Old Apr 5, 2008 | 08:26 PM
and i dont get my integra until next week so i need to know now .
Old Apr 5, 2008 | 08:27 PM
0h sorry & they are brand new JDM emblems from EBAY.
Old Apr 5, 2008 | 08:33 PM
DA_9's Avatar
Default Re: (H0NDAdAddy LS)
So probably not jdm, but hey it could be like kdm?
I agree though, grind and put them on. BTW I had a 91 integra and OEM civic H's did not fit it, hope that helps somewhat.
Old Apr 5, 2008 | 08:36 PM
how would i grind em with out snapping the hole thinqq lol
Old Apr 5, 2008 | 08:40 PM
redwing24's Avatar
grinding wheel if you have one, would be the easiest way to do it. If not take some snips and snip em at the base.
Old Apr 6, 2008 | 03:30 AM
Lro255's Avatar
Default Re: Will these Red Honda Emblems fit on an Integra ???? (H0NDAdAddy LS)
The one that say rear is for the front and the one for the front is for the rear. The rear is bigger and the front is hold down by a washer or spacer or something like that. I did my not long ago.
Old Apr 6, 2008 | 06:40 AM
jhammond_82's Avatar
Reject Papi
Default Re: Will these Red Honda Emblems fit on an Integra ???? (Lro255)
it is what it is, in ain't what it ain't so don't try to make what it is what it aint, because it'll still be what it is. please don't put h's on acuras. thats like putting a blue oval on a mercury. or a ram head on a plymouth. or a bowtie on a pontiac. it just ain't right. but i agree, if you must, and apparently you must, use 3m double sided tape.
Old Apr 6, 2008 | 07:31 AM
Lro255's Avatar
Default you need 90190-SB2-000 NUT, PUSH (4MM)
you need part# 90190-SB2-000 NUT, PUSH (4MM) for the front and *edit the back you need 3m adhesive but no need for shaving anything
http://www.acuraoemparts.com/d...ch=no
Modified by Lro255 at 8:37 AM 4/6/2008
Old Apr 6, 2008 | 07:36 AM
so the big one is for the rear and the smaller one is for the front ? thnx ill try it & if nothinq fits , imma grind it offf . thnx guys .
Old Apr 6, 2008 | 12:32 PM
Sumslapper's Avatar
Year 3030
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lro255 &raquo;</TD></TR><TR><TD CLASS="quote">
Nice car man people would kill for that front bumper with the fogs. Dont see it to often. And for the emblems just see if they fit in the holes first....and if they dont grind em off lol
Old Apr 7, 2008 | 11:43 AM
lol exactly what i was thinkinq . thanks sumslapper :]
Old Apr 7, 2008 | 02:16 PM
wegotmorrison's Avatar
Default Re: Will these Red Honda Emblems fit on an Integra ???? (jhammond_82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote">it is what it is, in ain't what it ain't so don't try to make what it is what it aint, because it'll still be what it is. please don't put h's on acuras. thats like putting a blue oval on a mercury. or a ram head on a plymouth. or a bowtie on a pontiac. it just ain't right. but i agree, if you must, and apparently you must, use 3m double sided tape. </TD></TR></TABLE>
Which isnt true.. Considering in other countries the Integra IS a Honda... And not all Honda Integras have different front ends... People just want to be different. Personally, the Acura badges are extremely ugly, and the Red H's look really good....
frankie11
Nov 11, 2007 07:04 PM
pdiddy
Feb 24, 2003 01:54 PM
