B-Series Swap Some Basic Questions
Old Apr 5, 2008 | 07:25 PM
SlipGear's Avatar
Default B-Series Swap Some Basic Questions
Well i am planning on swapping out my d15b/y8 setup for an ls. I just have a few questions for the swap: B18A1
1. Can I Use DA Motor Mounts?
2. Should I use my mpfi harness or swap in the LS harness?
3. I need to wire an 4-wire 02 Sensor in?
4. Will my dx knuckles accept b-series axles?
Thats it for now.
Old Apr 5, 2008 | 08:06 PM
JScott3d's Avatar
1.) You will need aftermarket mounts ie: hasport, innovative, ect...
2.) harness depends one the OBD of the ls
3.) Unsure myself
4.) DX and SI are the same. They will work. HF are the ones that will not work.
Old Apr 5, 2008 | 08:20 PM
.Manny.'s Avatar
Touching My Member
Default Re: (JScott3d)
you modify the stock harness to work with the new motor
Old Apr 5, 2008 | 08:47 PM
D16SiHatch's Avatar
Default Re: (.Manny.)
yep just pull the harness off your current engine and put it on the b18a1. if it is an obd1 b18a1 then you'll need the rywire conversion harness as well, and that will have an output for your 4 wire o2
bee015
14
Dec 28, 2010 12:04 PM
justhatched231
Jun 20, 2010 08:08 PM
absinthminded
Aug 31, 2008 04:48 PM
b18crxturbo12.1
May 1, 2006 01:24 PM
bradykiller
Jun 24, 2005 06:52 PM
