i am having trouble starting my 93 da plz help
i just did a wire tuck of the headlight harness and moved the battery to the trunk and when i cleaned up i went to try to turn it on and well the pump is working and everything but when i push the clutch in it wont turn over at all it does the little click like when u try to turn a manual car on without pushing in the clutch idk wht to do i am beating my head on this it will not send the signal to the starter or something plz anybody ?????
make sure you have the ground going to the transmission connected... without this ground from the battery/ frame to the transmisson as well as the ground at the thermostat housing, the car will not crank...check to make sure you have the 3 main grounds connected...1 the transmisson, 2 the ground at the thermostat and 3 the ground going from radiator support to the valve cover
u know wht i took of the engine ground the one from the the head to frame and well the other two are ok i will try it in the morning thanks everybody for the help.anything else tht it could be ???
Rob_Dog
15
Nov 10, 2004 08:58 PM
Fuzion
Sep 3, 2004 12:08 PM
