Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
rear koni adjustment for 10k spring
Old Apr 5, 2008 | 01:35 PM
1net's Avatar
Default rear koni adjustment for 10k spring
Hi guys, my konis are the older model that needs removal to adjust. Last night I put on some fresh 10k springs in ther rear and now the read is all jumpy. It seems that the yellows are a bit soft (1/2 turn from full soft) but since adjusting is quite a hassle, I decided to ask and probably save some time. I'm also a bit new on setting up shock stiffness, so a bit of advice on diagnosing too stiff or too soft shocks would be appreciated.
What I plan on doing tomorrow morning is the following, please if you have a better suggestion, tell me.
First, let me share this, when I go over a bump, i feel the bump from the front wheels and a momenta after that the car starts bouncing seemingly a moment after the rear has gone over the bump. This is felt at speeds above like 40kph... lower than that I feel no bouncing. An I correct in assuming that this is caused by soft rear shocks?
Assuming i have to stiffen the rear and that I'm 1/4 turn from full soft, I thought of trying just in the middle. If the bouncing continues, I'try fullhard. If it disappears, I'd soften a bit to see if it baunces again. correct? If anyone knows a good and tried setting for koni yellows (not revalved) with 10k springs and a stripped EF (15mm rear sway) please chime in and save me at least some trial and error
Thanks.
Old Apr 5, 2008 | 02:06 PM
STN_Pat's Avatar
Default Re: rear koni adjustment for 10k spring (1net)
you'll have to run them pretty much full hard with this spring rate
Old Apr 5, 2008 | 02:49 PM
1net's Avatar
Default Re: rear koni adjustment for 10k spring (STN_Pat)
fair enough... so I'll go full hard tomorrow.
But then, how does one recognize a shock that's too stiff? I know the ride gets quite harsh with way too stiff shocks, any other pointers?
Old Apr 5, 2008 | 06:28 PM
STN_Pat's Avatar
you'll feel it.
Go maybe a quarter from full stiff...it's really personal though !
Old Apr 6, 2008 | 02:25 PM
essex's Avatar
Of the shelf yellows can't handle 500?
Old Apr 6, 2008 | 02:58 PM
STN_Pat's Avatar
Default Re: rear koni adjustment for 10k spring (essex)
560 is pretty near of the hypothetic limit of the shock
Modified by STN_Pat at 5:06 PM 4/6/2008
Old Apr 7, 2008 | 03:21 PM
1net's Avatar
I Tried 1/4 turn from full stiff today. The car is much better.
I'm still not fully satisfied as in hard cornering on bumpy surfaces I still get some diagonal craddle like motion, but it's much better than before. I couldn't try full hard today, but I'll do that tomorrow.
In city driving, ther car is a bit jumpy, but I had the opportunity to try it in some kind of spirited mountain driving and it's actually pretty good. Much better than what i expected after driving in the city.... seems like speed somehow cures the bouncing a bit.
Thanks guys, i'll post more info when i try full stiff.
Golddddddd
Suspension & Brakes
15
Nov 14, 2012 10:27 AM
Zaraki
Suspension & Brakes
Apr 15, 2012 02:56 PM
DA9 Integra
52
Jun 29, 2007 09:47 AM
kellogg97rs
Suspension & Brakes
14
Mar 30, 2007 10:31 AM
Stefndogg
11
Nov 2, 2005 03:49 PM
