E-Brake Handle Cover on a Civic
Old Jul 10, 2002 | 01:40 PM
Campee's Avatar
Default E-Brake Handle Cover on a Civic
Hey, maybe this is a dumb question, but how do you install an E-Brake cover on a 98 civic? Do you have to take a hacksaw to your existing e-brake cover and cut it off? the cover I have is not large enough to slide over the existing handle. any suggestions would be greatly appreciated. thanks.
Old Jul 10, 2002 | 01:49 PM
Spade's Avatar
Default Re: E-Brake Handle Cover on a Civic (Campee)
I don't have my haynes (yes I know it sucks) but, I am almost positive you don't hack it off.
Old Jul 10, 2002 | 02:03 PM
Campee's Avatar
Default Re: E-Brake Handle Cover on a Civic (Spade)
Perhaps I should mention that it's one of those aftermarket ones, I will be replacing the stock grey cover w/ the new metallic one.
Old Jul 10, 2002 | 02:05 PM
Inaniac's Avatar
New User
I think that was a given
Old Jul 10, 2002 | 02:51 PM
Ya@inlinePRO's Avatar
perhaps you should just leave it gray? and save the 30 bux for some food? if you really want to know..just twist and pull, should come up...peace
Old Jul 10, 2002 | 03:15 PM
Campee's Avatar
Default Re: E-Brake Handle Cover on a Civic (kwik2nec)
You can't turn it. Have you succesfully done this? I'm ok w/ food, thanks..
Old Jul 10, 2002 | 03:30 PM
i did it a while back on a crx and i've done it on my ek just to clean the button, had this weird black stuff in between, of topic but anyways yea...just keep twistin it.
Old Jul 10, 2002 | 03:36 PM
hollywoodciv's Avatar
I'm pretty sure that Kwik2nec is right you don't want to try and cut it off because you may damage something that you don't want to, try his method and if it doesn't work take it to a shop that deals with these things. It may cost you some pocket change to have done but it is better than having to replace the emergency brake handle assembly.
Old Jul 10, 2002 | 03:56 PM
Campee's Avatar
Default Re: E-Brake Handle Cover on a Civic (hollywoodciv)
I feel like I'm about to tear the entire armiture out of the console... you guys use any lubricant? was it like insanely difficult to remove the handle? i'll keep trying i guess.
Old Jul 10, 2002 | 04:15 PM
Cashis Lee's Avatar
I did mine on a hot day. I took a mini vise-grip, locked it on, and just twisted it back and forth while pulling it out. Takes like 5 minutes max.
Old Jul 11, 2002 | 02:09 AM
Campee's Avatar
Default Re: E-Brake Handle Cover on a Civic (Cashis Lee)
didn't that destroy your cover?
Old Jul 11, 2002 | 07:43 AM
Dorikamu's Avatar
done it yet?
Old Jul 11, 2002 | 08:31 AM
Feuerraeder's Avatar
Default Re: E-Brake Handle Cover on a Civic (chusai)
I let the car sit in the sun for a few hours, and took a dremel and cut slices lengthwise down the handle, still took some grunt, but it came off
Old Jul 11, 2002 | 01:37 PM
Campee's Avatar
Default Re: E-Brake Handle Cover on a Civic (Feuerraeder)
I've decided that this is definitely NOT worth the trouble. =/
[Modified by Campee, 12:44 AM 7/12/2002]
Old Jul 11, 2002 | 07:36 PM
it really isnt...all that work and the handle i bought didnt fit, had to cut a slice down the bottom. damn autozone ****
Old Jul 11, 2002 | 07:59 PM
92CivicDX's Avatar
I installed an ebrake cover on my 92 civic a couple years ago. I just got a hacksaw and cut the old cover off. It took a while and I had to be careful, but in the end it came out fine.
jwarren1904
May 27, 2013 03:59 AM
santii7
May 19, 2009 02:29 PM
codenamezero
Feb 10, 2007 09:00 AM
SpiceyRice
Feb 12, 2005 07:13 PM
1.8tgsr
Feb 11, 2005 07:26 AM
