zc tranny vs si tranny?
i plan on doing a sohc(maybe dohc since no sohc are in stock at hmotors) swap into my 91 crx si.
from what i understand it is a direct bolt on swap, same distributer and ecu. does that also include the transmission? because my tranny has a few grinds (reverse and also second when driving hard) and the clutch is going bad. so basically, if it will bolt on directly i will just have my si one rebuilt. if not then i will just wait and order the tranny with the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nomoreavril »</TD></TR><TR><TD CLASS="quote">i plan on doing a sohc(maybe dohc since no sohc are in stock at hmotors) swap into my 91 crx si.
from what i understand it is a direct bolt on swap, same distributer and ecu. does that also include the transmission? because my tranny has a few grinds (reverse and also second when driving hard) and the clutch is going bad. so basically, if it will bolt on directly i will just have my si one rebuilt. if not then i will just wait and order the tranny with the engine.</TD></TR></TABLE>
Any zc or d series engine will bolt right up to your trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">Any zc or d series engine will bolt right up to your trans.</TD></TR></TABLE>
True.. but the 88 trans is a bit of a black sheep in the clutch department.
for syncros I would try hondaautomotiveparts.com and maybe do some searching.
It's best to replace the whole "sleeve set" and dont be surprised if the gear is slightly chewed up as well.
well i found some synchros, at least i think, but i am confused as to why it says 3-4 and 5 and thats it. also, WHY IS IT SO DANG EXPENSIVE! whats the point in rebuilding if the new one is about 1/10th the prce of ordering the tranny with the zc...
mario_pic
17
Feb 5, 2008 09:25 PM
smokez187
May 13, 2007 12:17 PM
ls_vtec_crx
33
Apr 3, 2004 09:19 AM
