shortshifter?
Old Apr 5, 2008 | 09:33 AM
ej6hatchie's Avatar
Default shortshifter?
im thinking of purchasing a short throw shifter from this local shop for 40$, there isnt realy anything on it. its jus the shifter itself i dont recall on what it comes with but i think its alloy, 40% reduce, and the case it comes in says "TYPE R" on it, kinda looks like a EBAY shifter but yea. should i get it? what can be the problems of a shifter like this?
Old Apr 8, 2008 | 09:05 PM
Kaiyoken's Avatar
i think that u should get it only if necessary.Because its only 40 might be a crappy one.up to you.
Btw wats good Brian.
Old Apr 8, 2008 | 10:01 PM
Dartanian's Avatar
Default Re: shortshifter? (ej6hatchie)
Keep the stock one. For $40, it is bound to be junk.
Old Apr 9, 2008 | 09:43 AM
ej6hatchie's Avatar
what can be the downfalls of using this shifter? cause yea ive heard some shortthrow shifters grind or rattle at high rpm?
Old Apr 9, 2008 | 04:56 PM
1992Si's Avatar
IMO this is one area where you get what you pay for.
I only use the Skunk2 STS. Put that $40.00 towards the real thing. You'll be happy you did.
Old Apr 9, 2008 | 07:20 PM
si vtec ftw's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej6hatchie &raquo;</TD></TR><TR><TD CLASS="quote">what can be the downfalls of using this shifter? cause yea ive heard some shortthrow shifters grind or rattle at high rpm?</TD></TR></TABLE>
ok as for the grinding
thats if you are a n00b driver,
as for rattling, maybe but i dont see how it would differ from stock
BUT i would suggest that if your stock shifter is a little loose when in gear(you can move it a good distance from side to side)
you should pick up a shifter bushing kit, they run about 30 to 40 bucks
i just got a bushing kit and a dc short shifter on a trade for a tranny linkage pin
oh yes, the spare bitch pin.
RHDintegXsi
Jul 23, 2006 04:19 AM
excivicboy96
13
May 8, 2006 10:20 PM
Kyles ej1
14
Oct 2, 2005 09:27 PM
ieatrice
Aug 1, 2004 09:04 PM
MyLittleRedCar
Jul 19, 2003 10:45 AM
