question about head torque spec and sequence / head gasket job
i bet there's a post about this, but i didn't seem to find any info about this
so if someone could point me to where i could find this out that would be great.
i have a blown head gasket and i have to replace it today/tomorrow. so we have to take everything off and have the heads checked out to see if they are warped or anything.
so if anyone has done this before and could give me some tips that would be bad ***.
thx in advance
-Rob
thx in advance
-Rob
Well, knowing what motor it is would help a ton.
And you are full of it if you can't find info on head bolt torque and sequences. Come on. Stop being lazy.
I'll let you search for the sequence because something like that shouldn't be handed to you when it will take 10 minutes to get a concrete solid answer.
Tips. Mill the head, use oem parts, make sure everything is at tdc. Loosen up your valves and try not to get too frustrated with the timing belt.
<(boogieman)>(666)
Feb 6, 2009 09:57 AM
