Need quick help. 90-91 92-93 LS transmission
Old Apr 5, 2008 | 08:31 AM
hondamn1320's Avatar
Default Need quick help. 90-91 92-93 LS transmission
what's the difference between the teeth on the 90-91 LS transmission and the 92-93 LS transmission input shaft? one is 32 and the other 34 or something like that, right? need some help asap. thanks in advance.
Old Apr 5, 2008 | 08:46 AM
MoonScryer's Avatar
The 90-91 have shorter length of teeth on the input shaft. If I remember right the clutch disc is what is different. Also possible difference on the TO bearing.
Old Apr 5, 2008 | 08:50 AM
Default Re: (MoonScryer)
so the 90-91 has less teeth than the 92-93. thanks that's all i needed to know.
Old Apr 5, 2008 | 10:26 AM
JScott3d's Avatar
same # of teeth on mine. Only difference was the 90-91 has a smaller input shaft. And the 92-93 has a larger shaft. The difference is 1/16in. Other than that everything is the same.
skidmarkroyalty
14
Mar 7, 2012 09:03 AM
-HONDA-
Aug 14, 2007 08:35 AM
RuthlessEF-9
Jun 17, 2004 03:16 AM
phat_gsr98
Apr 27, 2004 06:31 PM
