Question about DSS Axles Level 2.9
Planning on upgrading my axles to handle my new set-up this year. Motor is B18c1 with a '93 YS1 cable tranny. My current axle and intermediate shaft set-up appears to be directly from a 94+ GSR. I replaced the driver axle seal and found out it is for a 94+GSR intermediate shaft so I'm guessing both axles sides are also from the same year GSR. So DSS website sells this specific axle set for my set-up http://web.inetba.com/dss/item170651.ctlg should I get this one or just order the Integra GSR set http://www.driveshaftshop.com/item135622.ctlg I'm not sure what is the actual difference between the two sets but I'm guessing their 88-91 B-series swap axles is for use with a 90-93 intermediate shaft only? Am I right on this? If so then I will just order the 94+ GSR level 2.9 axle set.
Yes, get the gsr driveshaft set. ( which has a female driver side axle, a 90-93 mid shaft uses a male axle thats just like the passenger side)
