where do you install 4 point seat harnesses on a 5th gen?
I just bought 2 sets of Sabelt 4 point harnesses..and i dont know where to install them
anybody have any pics of their 4 point harnesses installed? or pics on where the harnesses bolt into would be great too.
What I did was attach the 2 rear points on the backseat lower seatbelt points.
for the front you can use the lower point on the doorside where your original seatbelt is attached and on the other side unscrew the bolt which attaches the seatbelt clip. and use that hole
lude is currently in the garage till I get a better job (study+appartment is sucking up all my money) so unfortunatly no pics, but here's a quick schematic:
hope it's a bit clear
on my lude I welded a metal plate on the inside part of the seats cuz I had a custom seat rail made for my seats, but this should work aswell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">You don't, unless you have a cage.</TD></TR></TABLE>
X2
It can be very dangerous with out a proper harness bar behind the seats. when the harness is anchored lower then shoulder height, when you have an accident the harness will pull down on your shoulders and crush your back.
Till you Seriously need them and can do it right, OEM FTW
X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Luda720 »</TD></TR><TR><TD CLASS="quote">
X2
you mean submarining. That is definatly true but I only did it this way cuz I've got a sparco harness with a anti submarining device
X2
