Ef front lip ?
Old Apr 4, 2008 | 10:17 PM
Awsom-o 4000's Avatar
Default Ef front lip ?
Will a lip from passwordjdm.com for a jdm front ef hatch fit a usdm front end? Thanks
Old Apr 4, 2008 | 10:26 PM
rayzian's Avatar
Default Re: Ef front lip ? (Awsom-o 4000)
It can fit the 90-91 front end after some modifications..
This is iheartteal's car from the EF Squad thread
and according to him:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">since its the jdmshit one, its made from polyurathane and very flexible, i used a heat gun (my sister blow dryer) and heat it up and stretched it around the side, it sucked and at first i thought i would never get it on. also u have to cut a little bit where the lip goes up to the grille</TD></TR></TABLE>
Old Apr 4, 2008 | 10:28 PM
Default Re: Ef front lip ? (rayzian)
hmm thanks. im unsure if i want to try it now...thanks though
Old Apr 5, 2008 | 06:40 AM
Slystone's Avatar
on my USDM CRX the password JDM fit!!
Old Apr 5, 2008 | 01:11 PM
rayzian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Awsom-o 4000 &raquo;</TD></TR><TR><TD CLASS="quote">hmm thanks. im unsure if i want to try it now...thanks though</TD></TR></TABLE>
yeah it sounds like a biyatch to get that thing on
Old Apr 7, 2008 | 07:42 AM
So no other lips for the stock front?
Old Apr 7, 2008 | 09:10 AM
rayzian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Awsom-o 4000 &raquo;</TD></TR><TR><TD CLASS="quote">So no other lips for the stock front?</TD></TR></TABLE>
Nothing you can just buy and slap on instantly, most lips you're going to need to modify (but it isn't that much work)
Old Apr 7, 2008 | 09:24 AM
akandok's Avatar
I have an OEM one from a 91 CRX, Brand new. LMK if you are interested. I decided to go with a JDM front end
Old Apr 7, 2008 | 01:10 PM
civicandy's Avatar
Default Re: (akandok)
RoadRaceGear makes a lip the bolts on directly to the 90/91 usdm hatch bumper. Otherwise you're stuck with OEM unless you want to modify something else.
Old Apr 7, 2008 | 01:48 PM
Default Re: (civicandy)
Will the oem one from a crx fit well?
Old Apr 7, 2008 | 05:02 PM
grog's Avatar
Default Re: (Awsom-o 4000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Awsom-o 4000 &raquo;</TD></TR><TR><TD CLASS="quote">Will the oem one from a crx fit well?</TD></TR></TABLE>
they sell one for the civic too, (probably the same part #)
it should fit better than any other lip made for other vehicles.
Old Apr 7, 2008 | 09:13 PM
Default Re: (grog)
Thanks. This may make me sound like a noob, but how do you order a part like that from honda? There website only deals with new stuff.
Old Apr 7, 2008 | 09:57 PM
crx_si-r's Avatar
civic and crx oem lips are different.
Old Apr 7, 2008 | 10:15 PM
Eighty-Nyne's Avatar
Default Re: (crx_si-r)
This thread helped out more than just the topic starter haha
Old Apr 8, 2008 | 04:29 AM
civicandy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r &raquo;</TD></TR><TR><TD CLASS="quote">civic and crx oem lips are different.</TD></TR></TABLE>
This is correct. Different part #'s. Here's a good place to get parts: http://www.hondaautomotivepart...y.jsp
You can also use other Honda/Acura lips and trim them to fit. I made a rear lip for my 90 hatch from an 86 Integra front lip.
Old Apr 8, 2008 | 07:11 AM
Tha t site is what I was looking for. Just to make sure, which part is the front lip? 1 or 6 or...Thanks guys
Old Apr 8, 2008 | 08:40 AM
civicandy's Avatar
6 is the lip. 1 is the filler between the hood and bumper
Old Apr 8, 2008 | 10:25 AM
Cool
Old Apr 8, 2008 | 10:33 AM
Ermil's Avatar
I like mine.
Old Apr 8, 2008 | 10:41 AM
Default Re: (Ermil)
The site above is out of them. ^^^That looks like a vw lip? What did you have to do to make it fit?
Old Apr 8, 2008 | 10:45 AM
Ermil's Avatar
It's a MKIII Volkswagen Euro VR6 lip. It fits right on. I drilled little holes and used toggle bolts. Works great.
Old Apr 8, 2008 | 11:03 AM
Default Re: (Ermil)
nice
Old Apr 8, 2008 | 12:36 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
» Search Results
Your search for lip returned 23 results.
and that was quick search, in the CRX/EF forum.
(This is NOT bashing the OP)
There is WAYYYYY too many of these threads.... maybe we should add a sticky of lips and what they look like at the top?
Cause theres gotta be a better way then having almost 25 of these threads in under 4 months.
Old Apr 9, 2008 | 01:47 AM
civickiller's Avatar
Default Re: (ComeOnKip)
here is my lip on my 91
i just dont know what car its off of, the guy i bought it from said its jdm thats all
Old Apr 9, 2008 | 04:11 AM
thevtecnician's Avatar
Default Re: (civickiller)
http://www.jdmcarboy.com/index...3_737
Chargespeed makes direct bolton lips specifically for the 88-89 and 90-91 usdm civic and 88-89 and 90-91 usdm crx. They are identical to the j'sracing/passwordjdm jdm lips. Above is a link for the crx though. Pretty pricey though. I just use 88-89 integra front lip and trim the sides
cayey911
Apr 8, 2008 06:07 AM
mr.scruffleston
18
Oct 25, 2007 05:22 PM
ys1civicsi
Feb 12, 2007 07:22 PM
crx98
Nov 3, 2003 06:14 PM
