Energy Suspension Civic/Integra Q
Hey guys, had a quick question. I just picked up a set of GSR front and rear brakes from my civic. I was thinking, since i had the parts out already, and since it needs a trailing arm bushing, i wanted to get the whole energy suspension bushing kit. Now here's the question, should i get the one for a 95 civic or for a 94-01 integra? Or does it not matter? Reason i'm asking is because i'll still be using everything else stock from the car. Thanks!
Edit: Btw, the main things im worried about in the kit are the Front End Links Set, Steering Rack Bushings, Transmission Shifter Stabilizer Bushings (manual tranny), Ball Joint End Boots, Tie Rod End Boots. Will those be the same? The control arm bushings have the same part number.
Also, since we're on the subject of bushings, anyone know if this bushing comes with the metal piece in the center that bolts to the chassis?
http://www.energysuspensionpar...=1025
Modified by Doc. at 12:33 AM 4/5/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doc. »</TD></TR><TR><TD CLASS="quote">Also, since we're on the subject of bushings, anyone know if this bushing comes with the metal piece in the center that bolts to the chassis?
http://www.energysuspensionpar...=1025</TD></TR></TABLE>
You reuse the stock piece. I wouldn't use poly for that bushing, though. OEM is best.
My_EFsedan
Oct 13, 2008 12:00 PM
cannan
Suspension & Brakes
Dec 14, 2006 06:09 PM
jeffh
Jun 13, 2005 07:34 AM
supadupamikey
Jan 21, 2002 08:48 AM
