CRX Swap Q...
As long as you use the HF's intake manifold, injectors, and sensors, as well as the HF distributor, you should be able to plug and play. The DX motor is DPFI, while the HF motor is MPFI, so essentially you will be doing a DPFI to MPFI conversion without having to worry about adding the extra wires.
SHG_Beans
Nov 27, 2003 07:53 AM
