HELP ME PLEASE!!!!!!!!!!!
hey guys i have a 93 LS ....i am having this issue with a vibration upon acceleration at low rpms, mostly in second gear. put my car on the lift at work yesterday to see if anything was loose. come to find out i had just put axles in it earlier this year and they are like wedged in there. i am assuming its because my car is lowered they are forced to bind almost instead of sit straight like they should. i raised the car a little bit to see if it would help and its just about the same. anyone else having the same problem? how did you fix it. basically i think i need shorter axles is there a combination of other b series axles with a different intermediate shaft that will make the length shorter to the hub from the tranny? i just dont wanna snap axles.
thanks for your help in advance if you view bump i gotta get this figured out!
Modified by EK 2 9K at 1:37 AM 4/5/2008
