Replacing a PCV valve
Old Apr 4, 2008 | 12:53 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Default Replacing a PCV valve
The prelude i'm looking at is a '94 S with a JDM H22. It has a bad pcv valve causing the idle to bounce at times. My question is, what kind of PCV valve would I look for because it's a JDM engine, would it be the same as a regular 4th gen?
Also, is it as easy as unscrewing the old valve and putting the new one in?
If I left any necessary info out, let me know. Thanks in advance.
Old Apr 4, 2008 | 12:58 PM
CHK4TIX's Avatar
Default Re: Replacing a PCV valve (5SpdH22)
To answer your question, yes they are the same. The pcv just pops into place and there is no "screwing" required. However, if your idle fluctuates, its probably not your pcv valve.
Old Apr 4, 2008 | 01:09 PM
Acidcrakker's Avatar
Idle surging can be any number of things. There is a good thread how to trouble shoot it here.
Old Apr 4, 2008 | 01:33 PM
SKDRCR's Avatar
The first thing to do is to check for vacuum leaks when
you have a bouncing idle.
Old Apr 5, 2008 | 10:17 AM
oranginal's Avatar
to check the pcv valve to see if it is working properly pull it out from the valve cover (leave all lines attached) Then put your finger on the bottom side (the side that would go into the valve cover)
If you hear a clicking noise then you know it is working.
It just pulls right out, no unscrewing needed.
Zaraki
Jun 22, 2013 08:57 PM
jhuerto23
Feb 14, 2013 08:06 PM
rpmraper
Jun 11, 2011 10:53 AM
cd5ryan
Jul 12, 2010 12:00 AM
justint
Jan 15, 2007 11:00 PM
