PICs....what are theset wo thingies called?
It looks to be an F22B2 Automatic transmission, and those are the lockup control solenoids A & B. There are two more further down on the front of the transmission and those are the Shift control solenoids A & B.
if you are talk talk about those two solenoids (In RED) the yellow one is the vtec and i dont know about the green wire one...i never heard of anyone useing gasoline to clean.
(Correct me if im wrong yall)
If you really need to clean them I would use some WD-40 or other lubricant to clean them up a bit. If you use a chemical cleaner or gas it will strip the metal of any sort of corrosion protection. If you do decide to use a chemical cleaner make sure to coat them with a lubricant after you are done cleaning them.
Read this link. It shows a picture of the solenoids, and how to inspect them. Clean them with carberator cleaner or brake cleaner, but not gasoline.
http://techauto.awardspace.com/transmission.html
CRseXy
Mar 15, 2005 08:45 PM
