coolant coming out of the dipstick?
Old Apr 4, 2008 | 10:05 AM
orange94teg's Avatar
Default coolant coming out of the dipstick?
i pulled the motor out of my integra and went to put it in my del sol. when i pulled the motor i changed the head gasket. now its in the sol and i was filling up the radiator and after a while it started to come out of the dipstick? can anyone shed some light. did i put the head gasket in wrong or wut?
Old Apr 5, 2008 | 06:38 AM
jhammond_82's Avatar
Reject Papi
Default Re: coolant coming out of the dipstick? (orange94teg)
i would have to say you did. or you might have over torqued the bolts and blew the gasket accidently. either way, you should change it again.
Old Apr 5, 2008 | 07:07 AM
Dogginator's Avatar
Daisy... Daisy...
You will need to open that engine. I would drain the coolant and the coolant. Then drain the coolant in the crankcase with an oil siphon. I drain the oil and pull the oil pan as well. You do not want to emulsify coolant with your oil. As said above, the head gasket must be leaking.
Old Apr 5, 2008 | 01:43 PM
mouab18c1's Avatar
Default Re: coolant coming out of the dipstick? (Dogginator)
same problem...just re-assembled my motor...and it drove fine...i checked my oil today and on my dipstick my oil lucked watery. so now im mixing coolant with my oil..any help?
Old Apr 5, 2008 | 02:06 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: coolant coming out of the dipstick? (mouab18c1)
Coolant mixed with the oil will wreak havoc on you bearings. Tear-down, clean, rebuild.
Old Apr 5, 2008 | 02:09 PM
mouab18c1's Avatar
fresh block resurfaced head..new gasket....
Old Apr 5, 2008 | 02:18 PM
i drained out all of the coolant pulled the head off put a new headgasket in put the head on but this time i left the drain plug out and once again its goin into the oil pan? i torqued the head to 22 ft lbs then agian to 63(wut i was told to do in two steps/stages) so is there any honses that could be backwards or sometin?
Old Apr 5, 2008 | 02:21 PM
mouab18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orange94teg &raquo;</TD></TR><TR><TD CLASS="quote">i drained out all of the coolant pulled the head off put a new headgasket in put the head on but this time i left the drain plug out and once again its goin into the oil pan? i torqued the head to 22 ft lbs then agian to 63(wut i was told to do in two steps/stages) so is there any honses that could be backwards or sometin?</TD></TR></TABLE>
do it in three steps...start with 20lbs then go to 40lbs then to 63-65lbs...
Old Apr 5, 2008 | 04:56 PM
should i buy new head studs or is it ok to reuse the stock ones?
Old Apr 5, 2008 | 05:01 PM
mouab18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orange94teg &raquo;</TD></TR><TR><TD CLASS="quote">should i buy new head studs or is it ok to reuse the stock ones?</TD></TR></TABLE>
you need new headstuds....stock oem headstuds stretch out after awhile so they are only meant for one time use....buy arp headstuds...good and cheap insurance for the long run....
Old Apr 5, 2008 | 05:25 PM
DiMpL3s.'s Avatar
Default Re: coolant coming out of the dipstick? (jhammond_82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mouab18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
you need new headstuds....stock oem headstuds stretch out after awhile so they are only meant for one time use....buy arp headstuds...good and cheap insurance for the long run....</TD></TR></TABLE>
X2
Old Apr 5, 2008 | 05:33 PM
Default Re: coolant coming out of the dipstick? (DiMpL3s.)
ok thanks
Old Apr 5, 2008 | 07:43 PM
mouab18c1's Avatar
jspinelli8
Mar 26, 2018 01:31 AM
YuJin
Oct 30, 2011 02:21 PM
cristegra09
May 14, 2009 11:45 AM
oranginal
Mar 30, 2009 07:39 AM
Raymund
Aug 8, 2003 07:41 PM
